At a loss... brake pedal
Old Jun 15, 2016 | 07:36 AM
Blurvision's Avatar
Blurvision
Get yourself a motive bleeder and have at it Or find a shop that knows more about track prepped cars.
Old Jun 15, 2016 | 06:34 PM
ShahulX's Avatar
ShahulX
yea thatll be the way i go..
suggestions for best track rotors? did a search...thinking stoptech drilled or slotted
Old Jun 16, 2016 | 05:53 AM
rancor's Avatar
rancor
Stoptech are fine but don't get drilled. You are risking the rotors cracking on the track. Drilled is only for looks at this point as modern pads don't outgass.
Get slotted or blanks, I think slotted are supposed to have a little more bite but the centric blanks are probably a little cheeper.
Old Jun 16, 2016 | 09:57 AM
ShahulX's Avatar
ShahulX
Ok, i will be running the stoptech slotted rotors on the 350z nismo's brembos (front and back), with goodridge stainless steel braided lines, carbotech xp12's front and back (will have to re-bed them with the new rotors), and torque RB700 brake fluid
I'll have a pro mod shop do it so I don't mess up.. granted we have speed bleeders..
If all that doesn't work, I quit... missed 2 track days now already...behind on my season
Old Jun 16, 2016 | 10:54 AM
Blurvision's Avatar
Blurvision
XP12 will be pretty aggressive for the rear, make your abs kick in overtime. But your setup should work regardless.
Old May 29, 2017 | 11:12 PM
GodISmE's Avatar
GodISmE
ShahulX, did you sort it out eventually? I have the same problem: brake pedal getting soft after a few laps/sessions at the track but then getting back to normal even already when driving back home on the same day!
LotusCorps
North Central
Apr 17, 2016 07:29 PM
Suspension
Mar 29, 2016 06:52 PM
Wheels Tires
Mar 22, 2016 06:56 PM
