Too Much Break?
Old Oct 4, 2016 | 12:48 PM
rizeld's Avatar
rizeld
Default Too Much Break?
Hey Gents,
Looking for track people's experience or other inputs.
Current setup which is:
Factory break system and factory size rotors with SS lines and,
carbotech XP 10 in the Front and XP 8 in the rear
Nitto 555 245/40 18 and 275/35 18
After my third track day on 2 different tracks my ABS seems to be kicking in on the rear only. I thought it my be my down shifting (usually 4-3) but i was experimenting and just leaving it in forth and its still doing it. I'm thinking on my current setup the XP 8's are doing too good of a job, or maybe I'm doing too much breaking.
Should I try going with one level lower (AX6)? Should I not suck? Some sord of other trickery? Deal with it until the tires run out and get something stronger? Sell the car and parts now before its too late?
Old Oct 4, 2016 | 01:25 PM
rancor's Avatar
rancor
It would help to know your model year and trim level to know what stock brakes you have.
The driver might need to ease up on the brakes but my thought would be to upgrade the fronts to XP12s to match the rear not the other way around. Seems odd with such a large stagger in tire sizes that the rear would be locking before the font.
One of the guys that actually tracks the car should have better answers.
Old Oct 4, 2016 | 02:17 PM
turboed350z's Avatar
turboed350z
ok first, its brakes. secondly, if youre running the oem brembo, they should be more than enough stopping power. thirdly, the pads doesnt do much other than dissipate the heats. other than bad pads, the initiate bit should be more than enough on most pads.
with all that said, if your abs is kicking it, its due to the system sensing that the brakes are about to lock up so it pumps it. i can only think of a handful of reasons as to why the abs will kick in on the track, and one of it being the driver. dont stand on your brakes as you brake entering the corner. if the tires starts skidding, youre braking too hard and too fast.
Old Oct 4, 2016 | 02:18 PM
rizeld's Avatar
rizeld
You're right. Started the question in my thread so I wasn't thinking. 06 base. I would tend to disagree with easing off as that would not get to the maximum breaking threshold. But that's why I'm asking
Old Oct 4, 2016 | 02:21 PM
rizeld's Avatar
rizeld
It only happens on fast straight aways like into turn 1 on summit main, and the bridge straight going into the karousel on Shenandoah.
Old Oct 4, 2016 | 02:22 PM
turboed350z
if it only happens in fast straight aways then i would assume youre braking too hard for the speed.
Old Oct 4, 2016 | 04:41 PM
rizeld's Avatar
rizeld
I'm not trying to be a smart a$$ here, but your answers are get a stronger more heat disapaiting pad in order to increase the chances of the abs in the front to kick in, and to increase my braking distance to inhibit the abs in the rear; which increases heat and degrades overall braking performance? Which also goes against the track mindset of getting to maximum braking threshold in the beginning and easing out until it's time to enter the corner. Or am I missing something?
Old Oct 4, 2016 | 05:31 PM
turboed350z
no, what im saying is, you shouldnt be standing on the brakes until the abs kicks in. it takes ALOT for the abs to kick in, so much so that when it kicks in, your tires should be skidding, and you shouldnt be skidding while braking on the tracks.
what im saying is pads have very little to the initial bite of the brakes. after the initial clamps, its the tires that are doing the stopping. the tires will skid much earlier than the abs should kick in, so if theyre kicking in, its liking youre braking too hard. yes its a thing.
now im not a professional driver but, there are very little that would lead to the abs kicking in, which, one of is operator error. my impression of your initial post is that you want better pads to stop the abs from kicking in, which i dont believe is going to help any. abs is there to stop the brakes from locking up, and the pads doesnt contributes too.
Old Oct 4, 2016 | 06:37 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Hey Gents,
Speculation...
I think it's pretty clear that you either don't have enough braking power if you are braking to the point of impending rear lock-up or your brake bias F-R is off.
That is, if it's a mechanical issue.
Something to consider here before you go about doing the mechanical diagnosis. While I'm not familiar with the turn or turn combination you're braking for, have you tried altering your braking points, e.g., instead of between brake marker 2 and 3 (or distance marked brake markers if that's more applicable), maybe earlier braking at 3 and trail braking down to the apex?
Driver compensation to "fix" braking issues later in a race (when brakes are hot or worn or otherwise overtaxed) is pretty common, particularly if you're not running in-car bias adjustment.
If that's not the problem then I would try increasing front braking power. That's where a larger percentage of your braking comes from so by increasing front brake, that takes some load off the rears which are obviously trying to work too hard.
OR... moving up to the XP10 (or comparable) at the rear as well to take more of the load. XP8, while a decent pad, isn't really meant for heavy cars like our Z's. XP8 works well on 2,000# cars better than on ours.
Finally, there's the question of tires. That rear size tire you quoted, being much shorter than the OEM size, might be feeding your ECU incorrect wheel speeds (higher than the ECU expects) and is triggering your ABS. Just something to consider.
Good luck tracking it down.
Old Oct 5, 2016 | 12:11 PM
rizeld's Avatar
rizeld
Originally Posted by MicVelo
Speculation...
I have noticed my speed is a little off due to the tire size.
I have tried changing brake markers, and noticed increased rotor temperatures which im not sure what to do about or how to interpret.
I replaced all the calibers last year (which doesn't mean much) and the rotors and pads are for the track only.
Without installing a brake bias I'm torn between going with xp 12 in the front or xp 10 in the rear. You have a personal choice/guess?
Old Oct 5, 2016 | 04:09 PM
MicVelo's Avatar
I can't give you an informed opinion on those pads. I run Bobcats (street pads).
One of our more avid/serious road racers, David (dkmura), recommends Carbon Friction on his T3 racer. (Chime in here, David...)
dragon11689
Oct 29, 2016 03:48 AM
UCSBalum10
Interior
Sep 13, 2016 06:19 PM
Dartys zz
Sep 11, 2016 02:42 PM
nizmo_0385
Sep 10, 2016 06:36 PM
