Gt-R Springs on a Z?
Old Oct 26, 2016 | 04:33 AM
SethY's Avatar
SethY
Question Gt-R Springs on a Z?
My old bosses husband owned a GT-R (2011 to my recollection) he was changing out his springs with some after market racing springs and offered to let me take the springs off of him. I'm now at a loss. I'm not sure if they will fit on the Z and every shop I have called and gotten in contact with can't seem to tell me either. I am sure there is someone in this world who has thought of this, but I can't seem to find it on the forum anywhere, and before you ask yes I used the search bar. So if any of you can shed some light on this, or can direct me to a link that can help? Thank you so much in advance; you guys rock!
Attached Thumbnails Gt-R Springs on a Z?-spring-1.jpg   Gt-R Springs on a Z?-spring-2.jpg   Gt-R Springs on a Z?-spring-3.jpg
Old Oct 26, 2016 | 05:24 AM
HRMoneyPit's Avatar
HRMoneyPit
Why? Let's just ask why would you even want to. Even if they fit it would probably raise the car cause it's so much lighter
Old Oct 26, 2016 | 05:34 AM
SethY's Avatar
SethY
Thats a solid question, I got so concerned with wether or not I could I didn't ask myself if I should. But honestly do you think it would raise my ride height that much? The GT-R is only around 300 lbs heavier?
350Z(2008)- 3,339 to 3,602 lbs
GT-R (2011)- 3,911 to 3,933 lbs
According to google
Old Oct 26, 2016 | 07:08 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Going to say no based on a simple part number lookup for a set of like-for-like (Eibach ProKit to Eibach ProKit for example) spring sets for Z and GTR. They don't jibe.
Of course, this isn't definitive. Only way to know for sure is to measure the springs both from physical size and spring rate (using a press to measure compression and rebound rates at 1" deflection) and compare.
Too much unknown and excessive work IMO for a set of springs, particularly when a good, KNOWN set of springs made for a Z are cheap; ranging from $125 to $350. Nothing, in the grand scheme of things.
And by the way, 300# is a pretty big delta in terms of suspension design. Almost 10% weight differential.
Old Oct 27, 2016 | 10:54 AM
Phenom's Avatar
Phenom
Toasty
I'd imagine even if they did fit, the springs would be quite a bit stiffer and the suspension would be underdamped. Might make the ride bouncy.
