'07 standard brakes caliper bracket bolt size
Old May 2, 2017 | 04:00 PM
bazguitarman's Avatar
bazguitarman
Default '07 standard brakes caliper bracket bolt size
Can anyone tell me the correct size socket for the front non-Brembo brake caliper brackets? I have read threads saying 21mm and others saying 22mm. I don't have either of these sizes in a 6 point 1/2" socket so I will have to buy. I don't want to buy both right now as $$$'s are tight. Thanks.....
Old May 2, 2017 | 07:04 PM
dcains's Avatar
dcains
Should be 21mm for the front and 19mm for the rear. Hopefully, you're using a 1/2" drive ratchet or breaker bar, because if they've been on there for a while, they'll be tight. PB Blaster helps.
Old May 3, 2017 | 06:21 AM
bazguitarman
Thanks for the info. Yes, I am usinh a 1/2" breaker bar to break these loose. I have also soaked them in PB Blaster. I also have a 1/2" impact if I need it.
