My parking situation
Old Sep 6, 2017 | 09:25 AM
Hypes's Avatar
Hypes
Default My parking situation
So I have to park on an uneven sidewalk and I'm wondering if this will have any short term or long term effects on the car any insight would be thankful
As you can see to the right it's a bit elevated it's not rough or anything though.
Old Sep 6, 2017 | 09:33 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Parking shouldn't have any affect on your Z. But jacking up your car and working on it is a no-no on an uneven surface like that.
Old Sep 6, 2017 | 09:40 AM
Hypes's Avatar
Hypes
Alright that's good to hear I was starting to think it may have some negative effects on the dampeners or something.
Old Sep 6, 2017 | 09:59 AM
Desert Z's Avatar
Desert Z
Are you thinking in terms of excessive chassis flexing? If it's not an extreme angle I wouldn't worry much. I have had to park in driveways like that.
Old Sep 6, 2017 | 10:06 AM
Hypes's Avatar
Hypes
So this should not be much to worry about than. Unfortunately I can't just sit the right tires leftwards were it's even due to how small the road is, someone would definitely scrape my car which has happened once to my other car.
Old Sep 6, 2017 | 12:37 PM
dkmura's Avatar
dkmura
The FM chassis the Z is built on is very rigid. There won't be any flex THERE. Perhaps if you left your car loaded on one side of the suspension for a couple of YEARS, there might be some spring deflection, but there'd be bigger problems that that to deal with.
Old Sep 7, 2017 | 05:50 AM
Atreyu'z 350's Avatar
Atreyu'z 350
None whatsoever. You're just going through ''new car paranoia''.
