Equivalent of B12 Pro kit but with SPL Rear Mid Links
Old Feb 1, 2018 | 12:59 PM
stascom's Avatar
stascom
Default Equivalent of B12 Pro kit but with SPL Rear Mid Links
The rear Eibach springs don't work with those links. Need 2.5" springs. Should I piece the shocks and springs separately or just get the kit and an extra set of rear springs that match Eibach? What would be a good match?
Thank you!
Old Feb 1, 2018 | 04:11 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Thank you!
Check with SPL on this. I seem to recall reading something on their site about spring recommendations or calculating what you may need for your application, be it street, track, auto-x, etc.
As a suggestion, the other thing you can do after you determine what type of springs are needed for the rear-mid-link, get a matched set F&R (example, a 2.5" Swift in the spring rate needed for the rear and another pair of mated Swifts for the front.)
Then.... Buy the B12 for the shocks alone - still cheaper than a la carte - then sell the ProKit spring set complete. No one wants half a spring set. And, this helps to offset the cost of the springs you NEED to work with the mid-link.
Old Feb 4, 2018 | 02:34 PM
Frostydc4's Avatar
Frostydc4
I'm pretty sure Eibach will sell you a 2.5" ID spring in any spring rate and length you want.
Old Feb 4, 2018 | 04:09 PM
MicVelo's Avatar
If you can find someone to sell you Eibachs a la carte, I’m sure that’s possible.
However, no vendor is going to break up the ProKit set bundled in the B12 Kit. That was the point of my saying to buy the whole B12 setup to get the B8s cheaper than piece mealing them and selling the set to offset cost of a different set that’ll work with the SPLs.
Old Feb 5, 2018 | 03:53 AM
stascom's Avatar
stascom
went ahead and ordered the B12 kit.
Now, finding specs on the Eibach springs is a chore.
Best I could do was find this list:
Oem spring rates 2003-2004 350z unrevised suspension
314/342
Oem spring rates 2004.5-2008 revised suspension
314/427
Eibach 350Z progressive springs 1”/1” drop
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
All other known 350Z aftermarket springs
RSR 350Z linear springs .6”/.6”
Spring rates in LBS 345/417
Hotchkis 350Z Linear springs .6”/.8”
Spring rates in lbs 340/330
Tein S-tech 350Z springs .7“.6“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein H-tech 350z linear springs .3”/.2”
Spring rates in LBS 358/375
Progress Technology progressive springs 1.0”/1.0”
Spring rates in LBS 425/385 (final rates only, softer intial front progressive rate unknown)
Tokico D-spec shock & spring package
350Z - DSK512 - 375f/375r - Linear Springs 1"/1.5"
Tanabe GF210 Series 350Z progressive springs 1”/1.2”
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown) Not much stiffer vs oem, IMO Eibach prokit is a better choice because of that springs higher spring rates which should help keep you off the bumpstops more often.
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” higher
Spring rates in LBS 314/353
Little to no increase in spring rate over oem, little to nothing added to keep you off the bumpstops
Swift 350Z linear springs .8”/.6”
Spring rates in LBS 336/364
Swift 350Z Spec-R progressive springs 1.2”/1”
Spring rates in LBS intial/final Front: 291/392 Rear: 280/448
Nismo T2 350Z Linear springs 1”/1”
Spring rates in LBS 690/690
Way too much spring for oem shocks or Tokico D-specs, HP, GR2 or Bilstein Sport(unless revalved). Koni sports are debateable.
Vogtland 350z progressive springs 1”/1”
Spring rates in LBS initial/final front 257/354 initial/final rear 285/422
DR21 super sport 15mm drop
Spring rates in lbs initial/final front 246/398 initial/final rear 252/409
Very wide spreads between the softer initial rates and firmer peak rates.
Kg/mm DRacing progressive springs 1.2”/1.2”
Spring rates in LBS initial/final front 252/454 initial/final rear 252/482 rear
Whiteline 350Z linear springs (control)
Front: Part # 73219,
Spring rate 365 LBS Drop: .8"-1"
Rear: Part # 73220
Spring rate 445LBS Drop: 1"-1.2"
(sold as 2 front springs and 2 rear springs)
www.whiteline.com.au/store/
Espelir 350Z progressive springs 10mm drop F&R
386/515 (softer initial progressive rates are unknown) {most often seen being resold by track guys that thought they were onto sonething based on the numbers}
H&R sport progressive springs 350Z 1.3”/1” drop
Spring rates in LBS 370/400 (peak rates only, softer initial rates are unknown)
So Eibach Pros are progressive in front and rear. No idea how long they are. And I'm not sure how close I have to be to that rear spec to not screw up the dynamic with the fronts. I see some other sets (Tein, for ex.) have progressive front and linear rear. Maybe get a set of linears that are closer to the final rating of the Eibach rears?
GmoneyGrip
Apr 24, 2017 12:04 PM
StratonAce
Jul 7, 2016 10:37 AM
