Can't lower ride right on Buddy Club Coilovers
Old Feb 5, 2018 | 08:03 AM
bcoffin23's Avatar
bcoffin23
Default Can't lower ride right on Buddy Club Coilovers
I have Buddy Club Coilovers (true coilover front and rear) with Swift springs.
My rear coilovers are completely bottomed out (screwed all the way into the fork) and damper is set to 4mm and there is still a 2 inch gap between my tire and quarter panel.
I can slam the front all the way to the ground no problem, but it seems like the shock body itself in the rear is to long. Or am I doing something wrong here?
Old Feb 5, 2018 | 05:12 PM
guitman32's Avatar
guitman32
Is it possible you have the wrong spring length? A picture is worth a thousand words...
Old Feb 5, 2018 | 08:59 PM
terrasmak's Avatar
What rear spring rate, are you running helper springs, ,what size tires are you running?
Old Feb 8, 2018 | 04:36 AM
bcoffin23's Avatar
bcoffin23
This issue has been diagnosed. The rear spring rate was almost 1.5x that of the stock spring rate of these coilovers . Since the shock body wasn't shortened to accommodate the stiffer springs, the rear was stuck sitting to high.
Old Feb 8, 2018 | 05:19 AM
guitman32's Avatar
guitman32
Nice, glad you got it fixed. Figured the rate was too high for the spring length. How stiff are you running in true coilover config?
Old Feb 8, 2018 | 05:41 AM
bcoffin23's Avatar
bcoffin23
Rear was at 650lb, stock should have been closer to 400lb.
So it was 50%+ above what those coilovers were designed for.
Old Feb 8, 2018 | 05:42 AM
bcoffin23's Avatar
bcoffin23
650lb in the rear. No helper springs.
bcoffin23's Avatar
bcoffin23
Length was okay, spring rate was way to stiff for the shock body.
Old Feb 9, 2018 | 04:30 AM
guitman32's Avatar
guitman32
Length and rate are directly correlated, the stiffer the spring the shorter is has to be to give you the correct ride height.
Anyway, thats pretty stiff for coilover config. You must be running slicks. Good luck!
Old Feb 9, 2018 | 04:56 AM
bcoffin23's Avatar
bcoffin23
I am changing the springs to an 8k rate that is designed for the shock body.
I run RSRR from Federal tires. It is not a slick, but a pretty aggressive track tire. Once I start trailering the car to races/TTs......slicks it will be!
Old Feb 10, 2018 | 10:21 AM
terrasmak's Avatar
Or you use shock length to set the amount of travel and where the travel is. Then use preload combines with helper springs if required to set ride height.
I know what combo the faster cars on the track are using.
Old Feb 10, 2018 | 10:35 AM
guitman32's Avatar
guitman32
^yup thats how its done buddy. I am familiar myself also
Old Feb 10, 2018 | 10:43 AM
guitman32's Avatar
guitman32
Wasnt trying to imply thats how he should set his up, but obviously there was a spring issue.
PikeZ_350
Mar 11, 2010 09:41 AM
