Better than 4 pot brembo
Old May 3, 2018 | 02:20 PM
SpartaEvolution's Avatar
SpartaEvolution
XP12 in the front and XP10 in the rear. The heat range on those pads is quite a bit higher than the heat range of any fluid on the market, so your fade is probably coming from boiled fluid. Again, brake ducting would probably solve all your issues, but a more 'bolt on' solution like stainless lines or Ti shims, both of which will help insulate the fluid from the hot environment, should help as well.
Guitarrocker98
Brakes
Feb 8, 2017 01:50 AM
highoctane247
Mar 18, 2008 10:38 AM
highoctane247
Mar 13, 2008 06:18 AM
Triji
Jun 29, 2006 09:12 PM
