front end clunking when turning
Old Jan 25, 2019 | 06:09 PM
aprilz's Avatar
aprilz
Default front end clunking when turning
my 06 350z front right axle makes a clunking noise when turning steering wheel. when I lookd underneath there was heavy grey grease on inside of rim. what is this ?
thanks april
Old Jan 25, 2019 | 06:49 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Welcome April- this buildup could be from a variety of sources. You need to jack the RF side up and take a closer look to be sure. One guess is the RF wheel bearing has failed and needs to be replaced. Only a manual inspection will tell for sure.
Be sure to comeback to this thread to let us know what you find.
Old Jan 26, 2019 | 06:41 AM
aprilz's Avatar
aprilz
Talking
Hi Thanks for the reply! I researched it a bit and you may be right. I noticed thick grey grease on my inner rim when checking that area. Will keep posting!
Old Jan 26, 2019 | 07:58 AM
dkmura's Avatar
dkmura
Also, it's important to mention that a wheel bearing failure is a critical part. It could result in a nasty accident if not repaired promptly.
Old Jan 26, 2019 | 08:44 PM
Chihuahuamaster's Avatar
Chihuahuamaster
I would think you could hear the bearing 'hum' at different speeds, if it has failed to that point.
Could also be your lower ball joint has failed. If this is the case, they should be replaced in pairs, or both sides. Also wouldn't be a bad idea to check for other loose/ worn suspension tie rods/ ball joints/ bushings, etc...
The clunking noise could be unrelated to your finding of the grease as well. Check your sway bar end links for play, i.e. can you move the sway bar back and forth with just your weight. This turned out to be the culprit of a clunking noise for me.
Freise
Jul 17, 2019 03:25 PM
khnitz
Jan 14, 2019 09:04 AM
dkmura
Jan 8, 2019 06:45 AM
whatZheck
Dec 23, 2018 07:10 AM
