Just installed TEIN basic coilovers....
Old Feb 22, 2004 | 05:17 PM
Ultimateone's Avatar
Ultimateone
Default Just installed TEIN basic coilovers....
Well I put the height at about halfway on all the threads on all 4 because its winter time here and there's no need to slam the car. WELL, both my fronts have a very similiar clunking noise but even more so on the right side...Me and 2 other friends tried to tighten every bolt as best we could but it seems(sounds) like the center strut bolt is loose. Anyone have any opinions??? or suggestions?
Old Feb 23, 2004 | 12:54 PM
Ultimateone
Anyone?
It seems to be that center bolt...anyone have ideas on how to keep it extra tight? Loctite?
Old Feb 23, 2004 | 05:16 PM
iLLestJrz's Avatar
iLLestJrz
Hmmm... Is there any play when sitting on the ground?
Old Feb 24, 2004 | 07:33 AM
Ultimateone
Nope, its definitely that center bolt, Im gonna get some loctite tonit and torque it to 59 psi per TEINs instructions.
Old Feb 24, 2004 | 12:29 PM
Sins4u33's Avatar
Sins4u33
what do u think of the TEIN basics coilovers?? i wanna get the TEIN flex with EDFC....ive seen them on a Z looks pretty good but i haven't been in to feel the ride...what do u think of the basics??
Ben
Old Feb 24, 2004 | 11:16 PM
weslutes's Avatar
weslutes
My set squeeks on the right rear coilover.If your talking about the nut on the top of the shock,I don't think it matters if the bolt is tight because the shaft cant spin.depending on how low you go will determine how high or low the nut should sit.I might be wrong.I tightend mine all the way down cause i plan on going lower
Old Feb 25, 2004 | 09:32 PM
little_rod's Avatar
little_rod
So Ultimateone, did you get this problem solved, and what are your thoughts on the basics???
weslutes, I am assuming you are saying that you have the basics too. So yours squeaks also and have you solved your problem?? What are your thoughts on the basics??
Old Feb 26, 2004 | 12:13 PM
Ultimateone
Yup Im all set now with ZERO noises.
Impressions are awesome, its not too stiff and it has got rid of the dreaded Z bounce. I have it set at about halfway and could down further and it gives a Great drop as is. I really like the Tein's so far and Im happy I went for coils as when I get my new wheels I will slam the car almost all the way
