Issues with SPL subframe bushings
Old May 5, 2019 | 10:36 AM
Glaceo's Avatar
Glaceo
Default Issues with SPL subframe bushings
Hi there, first post. I am installing solid aluminum subframe bushings on my 350, and I have the old bushings out. The frost bushings are very loose, I can effortlessly them in with one finger. Rear bushings i cant manage to get more than halfway in with one, and the other cant hammer in at all. My questions are:
1. Are the front bushings okay being loose?
2. What are my options for the rear bushings? I dont have access to a press, and I have tried heat/freezing the subframe/bushings.
Thanks
Old May 6, 2019 | 06:32 AM
coletrickle74's Avatar
coletrickle74
I just installed these myself not too long ago. 3 of my front bushings were easy going in and 1 needed some help. The rear one, I don't see how you could do it without a press. I got like 1/4 of the way in before it was a dead stop. I rigged up my own using the driver that came with the kit.
Old May 6, 2019 | 01:41 PM
260DET's Avatar
260DET
Would loctite help with the loose ones?
Old May 6, 2019 | 02:58 PM
coletrickle74
Dunno if I would call them loose. They just dropped in effortlessly. There was no movement once they were in. I wouldn't worry about it
Old May 7, 2019 | 05:41 AM
Glaceo's Avatar
Glaceo
Cool, thanks for the replies. I bought a press, so i guess Ill use that for the rear ones.
Old May 14, 2019 | 10:49 PM
terrasmak's Avatar
Forward mount ears on mine slid in , the rear one in the subframe was to be pressed.
1upZ
Suspension
Oct 8, 2014 08:25 PM
sriracha
East Canada
Jun 4, 2014 07:36 AM
vrbigdish
Suspension
Dec 11, 2013 03:21 PM
