what settings did you use on your hotchkis, what is your application
Old Feb 23, 2004 | 12:47 PM
JonathanG35's Avatar
JonathanG35
Default what settings did you use on your hotchkis, what is your application
what settings, front and rear, did you use on your hotchkis sways?
what is the application? street, autox, road race, etc.
thanks,
jon
Old Feb 23, 2004 | 01:34 PM
protocav's Avatar
protocav
i have a coupe and i am running full stiff front, and medium rear. i have a 245/275 20" tire package, and this feels very well balanced for the street. since you have 9.5/10.5 wide rims, i would do the same. i wouldn't go full stiff on the rear. this is not a direct comparison, however, since you have the flex system which stiffens the car up substantially.
Chad
Old Feb 23, 2004 | 08:28 PM
350Zteve's Avatar
350Zteve
I'm running full SOFT in the front and MIDDLE in the rear. This is a great setup on the street.
Old Feb 23, 2004 | 08:36 PM
AmyCroft's Avatar
AmyCroft
Smile Other Way
Middle hole in front ( medium )
Soft Far Hole in back. ( soft )
Have to kick the rear out someway.
Go to corner, don't brake, just turn.
Cheers Amy -
Old Feb 23, 2004 | 09:26 PM
AmyCroft's Avatar
AmyCroft
Default Re: Other Way
Cheers Amy -
Here is an old ( sic ) link to Sway's
https://my350z.com/forum/showthread....0&pagenumber=1
Cheers Amy -
Old Feb 23, 2004 | 09:39 PM
AmyCroft's Avatar
AmyCroft
Smile Why I said That - ???
Here is from HotchKis Web Site.
Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bars. Sway bar sets include front and rear bars, greasable bushings, and brackets.
Front 1 3/8" (35MM) Hollow (Bar Weight 13.5lbs)
3 Position Adjustable
Rate Increase over stock
+9%,+32%,+63%
Rear 15/16"(24mm) Hollow (bar weight 5.5lbs)
+54%,+92%,+146%
Retail price: $299.95
This item is currently Usually Ships in 3-5 days
I use Medium +32% front and Soft +54% rear ( that is over stock)
350Zteve is 9% over front and +92% rear - If he is in rain - slick he will spin.
Don't let the rear do it all.. I tried it in the rain this weekend... O.K.
Cheers Amy -
Old Feb 23, 2004 | 10:31 PM
Sponge's Avatar
Sponge
Great thread and great answer Amy. My Hotchkis bars are coming in soon and I was pondering this very question.
Old Feb 24, 2004 | 06:25 AM
JonathanG35
i was tempted to run full hard in the rear cuase i want to kick the end easier - is this flawed reasoning.
even with m y flex at 0,0 i still feel loose for daily cornering.
sales@czp
Sep 23, 2019 03:30 PM
