2005 350z vibration under braking
Old Apr 6, 2021 | 10:14 AM
statie.alexandr's Avatar
statie.alexandr
Default 2005 350z vibration under braking
Hello everyone,
I have a 2005 350z (track edition) with around 25000km. The car is used exclusively for track.
The problem that i am facing is a vibration in the steering wheel under medium braking. It goes away under hard braking.
Current state:
kw v2 suspension
ebc rpx pads and ebc race discs with stock brembo calipers
stock wheels with new semislick tyres
whiteline bushings + uniballs
I can’t figure out what’s causing the vibration. I know the discs and pads are ok (i regulary change the pads due to wear ), the tyres are also well balanced. I thought it’s bushings, but changed them and i see no improvement in the vibration.
Has anyone else faced this? Any ideas what could be wrong?
Thanks!
Old Apr 6, 2021 | 03:54 PM
travlee's Avatar
travlee
Master
How do you know rotors are okay?
Old Apr 6, 2021 | 04:21 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
This ^^ (have you mic'd them to measure runout and checked for warpage?) And, have you checked play in wheel bearings?
Old Apr 6, 2021 | 04:49 PM
travlee's Avatar
travlee
Master
Bearings would be second place to look
Old Apr 18, 2021 | 06:41 AM
FastFarmer's Avatar
FastFarmer
Make sure you aren't getting metal transfer build-up. One needs to clean the rotors with a number of very hard stops to resolve this problem.
gbodey
Mar 15, 2021 07:41 PM
ADVNTURR
Jun 9, 2017 09:22 PM
IamStrube
Aug 25, 2012 08:07 PM
go kart
Jun 28, 2010 01:07 PM
mark350
Aug 1, 2003 01:07 PM
