Front Upper Adjustable Control Arm (Suggestion)
Old Mar 28, 2023 | 03:02 AM
wcharon's Avatar
wcharon
Default Front Upper Adjustable Control Arm (Suggestion)
Hi to the Community...
I had to replace the Lower Control Arms and Tie Rods on my 350Z 2004 with OEM parts. Took it to Alignment and the Technician said i need new Upper Adjustable Control Arms in order to get the specs he wanted with the alignment.
Checked Z1 Motorsports and found several brands (Z1, Cusco and SPC) and will like your opinion which one to go with. My car is not lowered an i don't track. The car have 20" Wheels installed if that make any difference.
At the moment i am inclined in the Z1 Brand as i see that the Ball Joints parts are rebuildable and they sell in separate and can be exchanged if they get bad. Anyone with experience with these one or should i take another route?
https://www.z1motorsports.com/z1-pro...0d28954d8533ce
Thanks in advance.
Old Mar 28, 2023 | 05:59 AM
Heel Til I Die's Avatar
Heel Til I Die
I've got Z1. They do the job. They're kind of a pain to adjust since you have to unmount them in order to spin and adjust them, but if your shop is willing to do it, then you're good. SPC, Cusco, and Kinetix don't require that to get them into spec and a little easier to adjust.
Old Mar 28, 2023 | 09:38 AM
jhc's Avatar
jhc
General & Tech Moderator
Agreed, Z1s are a PITA to adjust, but mine have held up over 30K miles.
Btw your car will be much more spry if you went back to 18s, just saying 😉.
Old Mar 28, 2023 | 09:59 AM
wcharon's Avatar
wcharon
@Heel Til I Die Thanks for your input and sharing your experience.
@jhc Thanks. Yes i know a lot of people hate the 20" in the 350Z. I really love the way they fill the fender gap. To be honest i put those 4 months since i bought the car new. It is the first repair i do to the car so i am very satisfied with it. Still love it more than my Mustang GT 2019 PP1. I am a OEM guy but in this case have to go aftermarket. The car only have 75,000 miles only.
Here is a pic for reference.
Old Mar 28, 2023 | 10:55 AM
GreyZ's Avatar
GreyZ
Holy ****
Old Mar 28, 2023 | 12:30 PM
jhc's Avatar
jhc
Nice looking paint and tint, not a fan of your 20s, but hey, it's your car, enjoy!
Old Mar 28, 2023 | 12:33 PM
wcharon's Avatar
wcharon
Thanks. I understand. That paint is original OEM Sunset Orange.
Still in love since i got the car new.
Old Mar 28, 2023 | 02:15 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Late to the party but....
SPC FUCAs. They were originally recommended to me by Rob Fuller of Z Car Garage. I trusted his judgement and haven't looked back. Honestly haven't "needed" an alignment since I dropped it and the SPCs were installed but I've had it checked and/or re-done a number of times. My alignment shop thanks me for having the SPCs due to the adjustment ease and capabilities (as mentioned by Heel, above.).
Probably not as strong/robust as the SPLs but they were about a third of the cost (but higher than the cheap stuff - which aren't terrible).
Old Mar 29, 2023 | 04:06 AM
wcharon's Avatar
wcharon
I talked to Z1 Support and they stated that if the car is still with OEM parts to stick with the Z1. If the suspension have aftermarket parts and it is lowered go with the SPC.
I ordered the Z1 based on that so i will update as soon as i receive them. Here is a pic of the alignment specs that the car have now.
Old Mar 29, 2023 | 04:40 AM
travlee's Avatar
travlee
Master
wheels look like something a deep dish pizza would be made in
Old Mar 29, 2023 | 04:45 AM
wcharon's Avatar
wcharon
jajajajajjajaj. Yours should be a 2024 model with that invention on your head. Jajajajajajajjaj.
Old Mar 29, 2023 | 05:32 AM
travlee's Avatar
travlee
Master
nah, if i liked the c8, i would have one
Old Mar 29, 2023 | 05:42 AM
tuzzio's Avatar
tuzzio
I opted to go for the SPC 73000 for my Z. I don't like the idea of moving the ball joint location, and these offer caster adjustment, as well as replacement parts. Its a win / win / win to me. I can get you set up with a pair, if needed PM me.
Old Mar 29, 2023 | 06:50 AM
wcharon's Avatar
wcharon
@tuzzio Thanks.. I already ordered the Z1 but will PM you anyway.
Old Apr 5, 2023 | 05:31 AM
wcharon's Avatar
wcharon
Hi...
Just to keep updated the Upper Adjustable Z1 Motorsport Camber Arms where installed yesterday by the shop.
The alignment and the car came out great but i am having some squeaky noise only when i hit a bump. The shop will revise on Tuesday the car again but i also wrote Z1 for some suggestions and waiting for reply.
Have anybody have this same situation with the Z1 Motorsport Arms that can enlighten me?
Thanks in advance.
Old Apr 5, 2023 | 06:07 AM
Heel Til I Die
Hi...
Thanks in advance.
I had that issue. I greased the bushings using a grease gun with the zerk fittings. No more noise!
Old Apr 5, 2023 | 06:30 AM
wcharon's Avatar
wcharon
Perfect. That are Good News... Do you have to grease it regular or is a one time shot?
Old Apr 5, 2023 | 07:48 AM
Heel Til I Die
I did it once with some Sta-Lube Moly-Graph lithium grease which is a blend of molybdenum and graphite since I had some left over from packing some wheel bearings in a truck. No issues since only doing it once several years ago. Ideally, I should have used a silicone-based (PTFE) lubricant on the polyurethane bushings, but the lithium has held up just fine.
Old Apr 5, 2023 | 09:02 AM
wcharon's Avatar
wcharon
Perfect. Thanks for t@Heel Til I Die ...
Old Apr 5, 2023 | 12:42 PM
jhc's Avatar
jhc
They'll also sqeak if over-torqued.
