important question about judging brembo brakes
Old Mar 7, 2004 | 09:16 PM
benzz280's Avatar
benzz280
Default important question about judging brembo brakes
is there a way to tell visually if they are in working condition? Hope brake experts can chime in
Thanks in advance!
Old Mar 8, 2004 | 03:53 AM
westpak's Avatar
westpak
SFZCC
Well, if they are not installed you can only visually look at the caliper for obvious damage but that will mostly just be cosmetic, the only other thing to look at would be the rubber boots on the pistons to see if they are in good condition or cracked, but those are cheap and easy to replace.
Basically they should work without a problem, if you are not sure just buy a seal kit, they are cheap (25 bucks) which replaces the inner piston seal and outer boot, then all you need is an air source to push out the piston.
Old Mar 8, 2004 | 08:38 AM
benzz280's Avatar
benzz280
thanks for the advise, westpak.
Another dumb question, how can i tell if the brembos are from a 350Z and not from Subaru WRX Sti? I looked at photos and both look bloody identical
Old Mar 8, 2004 | 11:24 AM
benzz280's Avatar
benzz280
Is there a number on the back of the calipers i can see?
Old Mar 8, 2004 | 07:03 PM
benzz280's Avatar
benzz280
help anyone?
May 30, 2017 03:28 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
