Front Brake ducts installed!
Air gets rammed in to a hose at the front of the car and gets ducted into the inside of your front brake rotors. This increased airflow through the rotor vanes keeps the rotors cooler under heavy use on the racetrack. The advantages are less brake fade (less pad fade and lower chance of boiling your fluid) + durability of the components (your pads last longer and your rotors are less likely to develop stress cracks from the heat).
Originally posted by John
No, that somebody simply drives the crap out of his car at the track with some negative camber.
So do all the underpieces go back together? I noticed some hanging pieces in the pictures but that was probably to take better pictures
How long did it take to install?
And the $64k question, how much?
EnthuZ, mcclask and I have/are all getting the kit from N-tech engineering.
http://www.ntechengineering.com/
I am planning to install very soon. It costs about $260 if I recall correctly (I paid a long time ago).
All of the underpieces go back on after the install. THey were left off in mcclask's pictures so that the hoses would be visible.
EnthuZ - I'll send you a pm
Thinking about joining us at Mid-Ohio Rudy?
You know you want to be there...
I went to VIR South last weekend, which is notoriously hard on brakes, and had no broblems with overheating brakes. Brake pads is a different story, but as it pertains to this duct kit and my front Stoptech kit, they were fine. My pads smeared and I had bad uneven deposition problems on the rotors that grew worse, but that will be cured by using proper pads next time. So the bottom line is this kit works well if you are trying to maximize your brakes (which this car demands)!
Originally posted by Jason Bourne
I do but it's such a looonnnng drive. I'm not officially starting the track season until May but once I do, I'm going all out. I have 10 track days in May alone (Summit Pt, Watkins Glen, Lime Rock and Barber Motorsports).
And to repeat the million dollar question, how much does this ducting cost?
Also what did you do to use your stock seat as a chari... pics of how it is attached maybe.. I have been thinking of doing that with my stock seat but not had teh time to make anything.
