Who has installed the S-tune suspension?
Old Apr 1, 2004 | 11:20 AM
ZPirate's Avatar
ZPirate
Default Who has installed the S-tune suspension?
I'm interested in the Nismo S-tune suspension. For those who have it please provide some feedback to the rest of us. I am particularly interested in how it effects ride, bounce and handling. Is the lowered height a problem with curbs, speed bumps or driveways? Also has it improved or done away with the tire feathering demon? Sorry if this question has been asked before. I tried to search for it but the search function is not working properly today. Thanks.
Old Apr 1, 2004 | 12:19 PM
350zSpeedRacer's Avatar
350zSpeedRacer
Since the search isn't working, I'll do my best to answer your questions.
I've had mine on for just under a year now. The ride is noticibly stiffer, but the car no longer bounces like a stock Z does.
It only lowers the car about half an inch, so you really don't have to worry about any more curb problems than you initially did, unless you've got an aftermarket front lip--and well, that'll cause curb/speed bump problems as stock height as well.
And a proper alignment is what really helps the feathering. You'll need one after the S Tune is installed, anyway, so spend a few extra bucks and go somewhere other than a Nissan dealership to make sure things aren't out of spec.
Old Apr 1, 2004 | 11:17 PM
RANDY350Z's Avatar
RANDY350Z
I plan adding this kit when I get a roadster. I plan to add the Rays wheels, will there be a difference in clearence in the wheel well are? Or I should ask, will it look lowered or will it still appear to be stock?
Old Apr 2, 2004 | 04:39 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
It lowered my car 3/4" and after about 2 months ended up at 7/8". The ride is much better IMHO and the handling is awesome!! I also did the Sways, rims and tires at the same time.
Old Apr 2, 2004 | 07:04 AM
all_bark's Avatar
all_bark
I did it and it is a bit stiffer.. wheel hop is almost gone....
I honestly thought there would be more of a difference but maybe that is the point. the ride gets better, you just do not notice it all that much..
nanotech
Oct 2, 2015 05:02 AM
