Alignment question regarding new TSB
Old Apr 14, 2004 | 11:02 AM
zh.guitar's Avatar
zh.guitar
Leave your mark!
Question Alignment question regarding new TSB
So the new TSB says you have to return your vehicle to OEM wheels/tire sizes to get an alignment done.
My question is:
If you have aftermarket wheels (19") in my case, and you swap them back to OEM for an alignment, will it still be in alignment if you put the 19" back on? or Do you have to have the alignment done with the aftermarkets on for it to be accurate?
Another question:
Would the alignment specs be the same for the 19"s as the OEM?
One more question:
what are the latest alignment specs from Nissan?
p.s. thanks in advance for all the helpful info. I LOVE THIS WEBSITE!!!!
Old Jun 30, 2004 | 03:29 PM
slaponte's Avatar
slaponte
Since both Toe and Camber are angles (angle of toe-in and angle of lean), it follows that the size of the rims/tires would not affect either. So the theory is that once aligned, the size change won't throw off the alignment.
BUT, that assumes perfect wheels and tires, with identical perfect offsets... which is a big assumption. It would be better to align it with the actual config.
Disclaimer : I am not an expert and could be totally wrong. I am going on my limited knowledge of the angles involved.
Old Jun 30, 2004 | 09:13 PM
rosscoe's Avatar
rosscoe
I am a tech for twenty years and the spec wont change with the tire size
Old Jun 30, 2004 | 09:18 PM
zh.guitar's Avatar
zh.guitar
Leave your mark!
THANKS!
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
Alexreyes
Sep 30, 2015 11:30 PM
