installing swaybar
Old Apr 19, 2004 | 07:37 AM
Vlad's Avatar
Vlad
Default installing swaybar
How difficult is to install front swaybar and bushings?
What are the main steps? What time (for unexperienced mechanic)
Thanks
Old Apr 19, 2004 | 07:56 AM
Gsedan35's Avatar
Gsedan35
Here's a how to thread for ya Vlad. It's not a hard install, but I was glad it was over when I was done.
https://my350z.com/forum/showthread....hlight=350EVO:
Old Apr 19, 2004 | 08:36 AM
350zSpeedRacer's Avatar
350zSpeedRacer
It's not too bad. I've done installs on my car, as well as a couple others. Biggest PITA--getting the rear sway bar that's desgined for single exhaust over and under all the parts to get it out from under the car.
Old Apr 19, 2004 | 09:18 AM
Vlad's Avatar
Vlad
I'm installing only front. Is there a chance to screw alignment, as described in that link?
Old Apr 19, 2004 | 09:22 AM
350Zteve's Avatar
350Zteve
If your just doing a sway bar, I don't see how its possible to alter the alignment at all. The only spec you can align in the front is toe and that's controlled entirely by the tir rod ends.
Old Apr 19, 2004 | 10:20 AM
Welsh 350Z N's Avatar
Welsh 350Z N
I installed Nismo front and rears myself with help from my neighbor following the instructions and reading a couple of threads (including the one above). It went pleasingly well. He's quite handy but neither of us are mechanics. However, I did have Eibach's installed at a shop the next day and had full alignment done at that time.
Old Apr 19, 2004 | 12:59 PM
D_Nyholm's Avatar
D_Nyholm
The hardest part with the front swaybar was getting the 17 mm nut off of the endlink. I had to use my 1/2" drive and use a prybar against one of the suspension pieces to get the leverage to get it off. Only one was really hard, the other one I could get off with just the ratchet.
I also ran into a problem when I bolted the 17mm nut back on. After a few days, it would loosen up and start banging around. I had to use a little loctite on it to keep it from coming loose. I think the 350EVO bars come with new endlinks, so you shouldn't have a problem with that.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
