Pointers for JIC/Coilover Install?
Old May 8, 2004 | 07:21 AM
mcclaskz's Avatar
mcclaskz
Default Pointers for JIC/Coilover Install?
I just got in a set of JIC FLT A2 coilovers and will be installing tomorrow. Can anyone tell me of anything in particular that I need to know to make it easier? Anything regarding taking the stockers out, or tuning would be helpful. I already have the factory service manual, but I figured there ought to be a few of you on the other side of the learning curve...
Old May 8, 2004 | 07:44 AM
Gsedan35's Avatar
Gsedan35
In the front I found that the easiest way to remove them is to jack up the suspension and remove the sway bar end link bolt. Once removed this will allow enough clearence to simply remove the whole shock/spring assembly.
In the rear the shop manuel has got it down pretty good.
Good luck with the installation.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
