AP 6 piston Brake kit, any good? I want to upgrade...
Do any of you have this brake kit? If so how do you like it? I'm looking to upgrade my brakes, can't decide what to go with just yet...
dumbcurse,
That's a clear indication that the kit is probably too front biased. Companies do that to make you think you have more 'stopping power.' In reality, brake torque is most likely shifted to the front, which could actually decrease your stopping distances because the rears aren't contributing as much as they should. Please check out this article:
http://www.stoptech.com/whitepapers/...erformance.htm
Just from the sensation of abrupt stop is not sufficient to come to a conclusion that the car has too much forward brake bias. The sensation just come from the high deceleration. Both a well brake balanced car and a forward biased car will give the driver the same sensation (provided the car is traveling in a straight line). Just like you cannot measure brake balance with just a single 1 axis accelerometer.
The stop tech paper explains the science of braking and brake balance in plain English, so you do not need to take dynamics and rigid body motion in college.
My previous post was just simply stating that my experience with the AP's deceleration qualitatively using my built in biological sensor in my inner ear. And in no part constitute promoting AP's caliper kit. I am sure Stop Tech, Endless, Brembo ...etc also produce quality aftermarket brakes.
I myself do not believe my half hearted tinkering can outdo the factory engineers who spent months and years in development and tuning. I am sticking with my stock brakes, and spend my money for driving schools instead. For the most cost effective performance upgrade is to tighten the "loose nut" behind the steering wheel.
Fair enough dumbcurse...any number of things can cause an overboosted feeling on the pedal. I should not have phrased my sentence as 'a clear indication that it's front biased.' All I will say is that people perceive 'grabby' brakes as being better, or stopping the car more quickly...which is obviously not the case at all. A friction change can do that...as can a master cylinder, different piston sizes, a different sized rotor, etc. Magazines don't help the cause, as they typically say, "the BBK upgrade put me through the dashboard...blah, blah." My point was simply, don't think that a grabby, short pedal means the brakes are working optimally. Obviously you realize this, but your post didn't indicate that. Many others don't realize this.
I agree with your assessment on the driving schools as well. That said, I think you'll find that after you gain a little bit of driving experience in the Z on the track, you'll see that the stock brakes are a definite weak link in the chain (vs. what the rest of the car can do). Then you see under, under, understeer rear its ugly head, and you'll spin the stock LSD into a froth.
We always recommend that people first try a race pad, fluid, and ss lines as a first step towards better braking on the track. When you exceed the limits of that setup and need more heat capacity...then get a front bbk.
I'm not sure what you mean by this, but as I said above, some simple upgrades such as pads, fluid, and lines do definitely improve the factory setup. As for the engineering and testing behind our BBK's, some of the OEM manuf. come to our engineers to help them with their tinkering.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
