Negative Camber After Mounting 19s??
Old Jun 22, 2004 | 02:19 PM
g35thanh's Avatar
g35thanh
Default Negative Camber After Mounting 19s??
My rear tires are noticeably slanting in now after mounting my 19s...is this normal?
thanks
Old Jun 22, 2004 | 03:52 PM
Audito350Z's Avatar
Audito350Z
you always had that camber in the back, but now that you have wider tires, it's more pronounced... nothing to worry about
what wheels are those? hard to get a good look in the tiny pic, but they look good from what I can see...
Old Jun 22, 2004 | 04:13 PM
g35thanh's Avatar
g35thanh
19" Axis Hiros
Old Jun 22, 2004 | 04:50 PM
b3n84's Avatar
b3n84
can someone explain negative camber to me?
Old Jun 22, 2004 | 04:54 PM
g35thanh's Avatar
g35thanh
negative camber is when your wheels slant inwards. It usually happens when you lower your car. Negative camber can cause quicker wear on the inside of your tires...
Old Jun 22, 2004 | 04:55 PM
2003z's Avatar
2003z
its when the top of the wheel tilts in and the bottom tilts out.
Car
negative camber
Car
neutral camber
Car
positive camber
Negative camber will give you better cornering ability, since the car leans to the outside in a turn, but wears faster than neutral.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
