JIC adjustments
Old Jul 1, 2004 | 04:38 AM
konspec's Avatar
konspec
Default JIC adjustments
I just installed my jic flt a2 coilovers. Dumb question; regaurding the rear dampning adj. With all of the plastic off of the rear brace i found black plate with many bolt on both ends, do i need to take those off every time i want to adj the dampning? can i leave them off or do they serve a purpose? Basically i'm just looking for the most efficeint way. blah
Old Jul 1, 2004 | 06:12 AM
mcclaskz's Avatar
mcclaskz
Yes you need to take those off to adjust. If you havn't done already, you will need to drill a few holes to put the allen wrench down there. I have the 10kg/mm front w/ 12kg/mm rears and have found 8 stiff front and 5 stiff rear to be a pretty good setup for the track. I also have my front sway set to stiff and rear set to medium. Good luck...
Old Jul 1, 2004 | 06:25 AM
konspec's Avatar
konspec
thanks for the insight, now i have an excuse to drill. There has to be some kind of unsightful rig i can make for easier adj.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
