Allignment Specs after Eibach Install.
Old Apr 19, 2004 | 02:29 PM
krutoydude's Avatar
krutoydude
Default Allignment Specs after Eibach Install.
Could someone provide me with allignment specs after eibach springs install? Thank you.
Old Apr 19, 2004 | 02:32 PM
slaponte's Avatar
slaponte
After the Eibach springs are installed, you need to have the car aligned BACK to the latest alignment specs.
To achieve this, you (might) need adjustable camber arms for the back and (might) need adjustable A arms on the front.
I got the adjustable camber arms on the back (see Sig) and got back to spec on the dot. I did NOT get the front A arms, too much money for 0.02 adjustment...
Check the latest TSBs for the latest alignment specs.
Old Apr 19, 2004 | 07:31 PM
JawKnee's Avatar
JawKnee
Post alignment specs for my Track lowered on Eibach Pro-Kit springs:
LF: -1.8 for camber, 8.8 for caster, and 0.03 for toe
RF: -1.8 for camber, 8.7 for caster, and I think 0.05 for toe
LR: -2.0 for camber, 0.04 for toe
RR: -1.8 for camber, 0.05 for toe
Old Apr 19, 2004 | 07:39 PM
krutoydude's Avatar
krutoydude
JawKnee, thanks a million.
Do you think enthusiast model should be ok with these specs?
What happened is that I lowered my car like 6 month ago and after two month I alligned it at some shitty shop and while doing my oil change the other week I noticed that my front right tire is bold on inside and that's why I have to reallign it.
Old Jun 30, 2004 | 02:14 PM
basam350z's Avatar
basam350z
Default CAMBER
JawKnee,
Do you have a camber kit on the back. Because according to the service manual you are within spec for camber.
Old Jun 30, 2004 | 03:34 PM
slaponte's Avatar
slaponte
Many eons ago I said I would post my nums after Eibach and caster arms on rear. Here they are :
Front
Camber -1.5 -1.5 (bad, Max -1.3)
Caster 8.7 8.5
Toe 0.04 0.07
Rear
Camber -1.5 -1.4
Toe 0.10 0.11
At the times, only my front camber is off by -0.2. But camber is not adjustable in the front. So I have been considering adjustable front camber arms.
Now, with the new TSB, Toe is deemed to be excesive. I am working on getting those two values adjusted properly. I get feathering every 8K miles or so, on the front, due (per Nissan) to the toe.
Old Jul 1, 2004 | 06:45 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
you HAVE to get the rear camber kit to get the spec close to factory... at least from my experience with Eibach springs..
Old Jul 1, 2004 | 12:04 PM
slaponte's Avatar
slaponte
I do have the camber arms for the rear. It went from -0.4 and 0.0 (BAD) to -1.5 and -1.4. The specs I had at the time called for rear camber between -2.1 and -1.1.
Actually, everything is ok except front camber which is not adjustable, so I am looking into front camber arms. But I am off by -0.2 degrees, which ain't much. Now I have to get rid of the TOE to eliminate the feathering.
Old Jul 1, 2004 | 05:48 PM
basam350z's Avatar
basam350z
This might be of interest to you slaponte:
http://www.350zmotoring.com/forums/a...opic/4974.html
Old Jul 1, 2004 | 08:03 PM
slaponte's Avatar
slaponte
FOr what I know, the toe on the back is ok. Since the Eibach drop is minimal, the camber arms brought camber to within spec and toe is ok (rear).
Camber in front is out (not adjustable) and toe is within spec but not per latest TSB. So when I go now, I want to solve two things : toe in front to TSB spec to solve feathering and camber arms to bring camber to spec in the front.
Thanks for the link. Interesting how a little thing like enlarging the bolt hole can give you the 1 degree +/- adjustment you need...
Old Jul 1, 2004 | 08:15 PM
Gsedan35's Avatar
Gsedan35
SPC now offers toe cam bolts with more adjustment then oem.
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
