Suspension UPGRADE
Old Jul 6, 2004 | 02:20 PM
zonester's Avatar
zonester
Default Suspension UPGRADE
What's the best coilovers under 1K??? I'm leaning towards either Tein Basic for about 750 or Tanabe Sustec Pro S-OC coilovers just under 1K.
I currently have 19's all around with Eibach pro springs. Any sugestions from anyone here who either knows someone with similar setup??? I need to upgrade ASAP. My tires are wearing uneven (camber problem).. Thanks,
Rich
Old Jul 6, 2004 | 02:43 PM
wren57's Avatar
wren57
If the only probem you have is camber, coilovers alone won't fix that. To fix camber and keep your drop, you will need to get rear camber arms and adjustable front a-arms (both kinetix and 350evo sell these). If I were you, I would spend $700 on Koni Shocks and $220 on Kinetix adjustable rear camber arms. This will give you a much better ride in addition to fixing the camber in the rear.
Old Jul 7, 2004 | 10:10 AM
zonester's Avatar
zonester
so with this koni shocks, I can keep the Eibach pro springs and also add the kinticx camber ajduster to fix the problem and also create less bouce...?
Old Jul 7, 2004 | 09:19 PM
snolden's Avatar
snolden
yes that is correct. having spent the money on the eibachs, i would consider the koni's or waiting for the tokicos (same ballpark price, double the adjustability)
But if you want performance that bad wait another month and put together another 500 and get the next step up teins
