Track/ Brembo Brake Noise...
Old Oct 15, 2002 | 07:48 PM
schindem's Avatar
schindem
Default Track/ Brembo Brake Noise...
I have a Daytona Blue Track with the Brembos- of course. I took it to Nissan dealership today because I've been noticing a high pitch when I apply just a little pressure to the brakes when in traffic/waiting at a light...
The sound seems to be coming only from the front brakes. They said it looks as if the pads are wearing unevenly and that on one edge the surface is smooth, the other rougher and grainy-like. They are ordering new pads and will install next week, I just hope this fixes the problem. Very annoying when coming to a halt in traffic and screeeeeeeeeeech, oh that sounded like ****. Even with my new stereo cranked, I know they are squealing and it is driving me nuts!
Anyone else with the Track/ Brembos having this problem, remember only very light tapping on the brakes, not a regular stop. Of course I do have 2800 miles on her, so maybe it takes a while for this to start... or I'm just an unlucky soul with squeaky brakes and oily streaked windows!!!
Let me know if you have had any trouble of this sort, thanks...
late-
Old Oct 15, 2002 | 08:09 PM
alphaz's Avatar
alphaz
I've got a Track. i do not have the brake noise but I do have the window streaks. If your windows are tinted try not to raise and lower them too much until the rollers are replaced. i have heard that it will cause problems with the tint.
Old Oct 15, 2002 | 08:26 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
i had brake noise... for about 50 miles around 1700 ... went away..
the streaks arent going to hurt anything... just keep wiping them often.
Old Oct 15, 2002 | 11:11 PM
fdao's Avatar
fdao
I too have the screeching noise on my Track model. Appears to be from the front as well. Seems to be less frequent now with 1200+ miles.
Old Oct 16, 2002 | 05:18 AM
Thunderbolt's Avatar
Thunderbolt
Charter Member #88
Default Re: Track/ Brembo Brake Noise...
Brembro have two pistons per caliper. One larger than the other. The larger one will be on the trailing edge of the pad and the smaller one on the leading edge. If you do not do hard braking the larger piston will be the one that applies the most pressure to the pad and the pad will look like it is wearing funny. This is normal on street usage. Dont worry about it. You will still stop on a dime when needed.
The noise is caused by the pads moving back and forth when they lightly touch the rotating rotor. Your dealer will have to apply a anti squeal agent to the new pads to stop the noise. Permatex makes a very good one and the tech should know about it.
Old Oct 16, 2002 | 09:40 AM
ChinaClipper's Avatar
ChinaClipper
Default No noises here!
2600 miles on the odometer with no noises or other Brembo protestations! My only complaint is the amount of brake dust thrown out, but baby, those metallic orange Brembo calipers look so sweet behind those Ray's wheels!
Old Oct 27, 2002 | 01:03 PM
wizeline's Avatar
wizeline
Default I HAVE NOISE!!
2725 on the Odometer and I still have breake noise on my Brembos!!
I guess I have to goto the dealer!
Anyone know if there are metalic pads avalible for the Bremo Kits yet? The brake dust cleaning is exhausting!
Old Oct 27, 2002 | 05:53 PM
robertchen's Avatar
robertchen
Default Re: Re: Track/ Brembo Brake Noise...
I thought the track model with brembos are 4piston calipers... and 2pistons rear.
Old Oct 28, 2002 | 04:00 AM
ChinaClipper
Default Re: Track/ Brembo Brake Configuration
Robert, you are indeed correct. The description by thunderbolt described the PAIR of pistons (large and small) on the front calipers.
The Nissan calipers are "floating" and move side to side (laterally) under brake operation. Thus, the two front Nissan pistons operate on only one side of the rotor and the caliper moves laterally to equalize the pressure on both pads/sides of the rotor. Because of friction, the piston side of the caliper ends up exerting more pressure than the other, so the pads end up wearing unevenly - the pads directly under the pistons wearing out quicker.
Brembos by contrast have a "fixed" front caliper with four pistons - two pairs operating opposite each other to TRULY equalize pad pressure and maximize brake pad application/efficiency. Same goes for the single pair of rear pistons opposite each other on the Brembo set-up. Brembo pads should wear more evenly between the inside and outside pads.
HTH
Old Nov 9, 2002 | 08:00 PM
nanhead's Avatar
nanhead
I test drove a Daytona Blue Track model earlier this week and asked the salesmen if they knew about the noise. He hadn't heard about any noises until I can to a slow stop and we both heard it. He was pretty surprised at hearing the noise.
Old Nov 10, 2002 | 01:23 PM
cobalt's Avatar
cobalt
"Race" type calipers will have a greater tendency to produce noise, especially when used with a compound having a coefficient of friction approaching 0.40mu. The reason is that most race calipers (non-sliding) do not have anti-vibration/rattle clips or other noise reducing mechanisms, as these are considered to be unnecessary for "track/race" use. Some systems have pad retraction devices, which provide positive retraction of the pad when you release the brake pedal.
With regards to noise until light braking, try going out and doing 4-6 moderate to heavy deccelerations (increasingly greater brake pedal pressure as you go) from 45-55mph on an open road without traffic. Use firm brake pedal application, but do not "stab" or "jam on" the brakes. Follow these braking manouveres with 10-15 minutes of cool-down driving. If you have any uneven wear/bedding of the brakes, such as can be observed by irregular wear patterns on the rotors, this procedure should take care of it.
All brake pads need to be bedded in to ensure proper function and longevity.
HTH... -Andie
Old Nov 11, 2002 | 05:47 PM
Chebosto's Avatar
Chebosto
is the noise high pitches squeel? might just be dust btwn the pistons and the back of the pad.
i had clicking noises on my brembos for my maxima. but i just rebled the lines and it fixed it
did you know that the pistons are magnetic, to pull back the back of the brake pads?
neat.
Old Nov 11, 2002 | 07:38 PM
articfury's Avatar
articfury
Charter Member #55
Chesbostos-
The noise I hear on occasion doesn't sound like normal brake pad noise. My previous car was an MR2 T with Porterfield R4S pads. After 6 months the pads started squealing, like a lot of the hi-perf pads.
The sound I hear only occurs at slow speeds and light pressures. It is sound different than any I have heard from brakes before. Not sure what's causing it. I am still trying to find the circumstances that causes the sound.
JD
Old Nov 12, 2002 | 09:05 AM
TRACK350z's Avatar
TRACK350z
Arrow
Mine squeeked a little this weekend, i had 650mi.
Has not done it again, i have 900 miles now.
Old Nov 12, 2002 | 09:14 AM
SandMan's Avatar
SandMan
No squeaks here. Brakes are amazing for me. I only have 200 odd miles on it, but hopefully it won't have any problems.
Old Nov 12, 2002 | 06:52 PM
Thunderbolt
Charter Member #88
Default Re: Re: Track/ Brembo Brake Configuration
HTH
You are so right. It has been a while since I have worked on the Brembos and I had just forgot about how they worked. Thanks
Old Nov 20, 2002 | 12:58 PM
Nate's Avatar
Nate
I have loud Brembo brake squeal at low speeds and light pedal pressure as well. Still doing this after 600 miles.
Has anyone found a fix for this?
-Nate
LeMans Track
Old Nov 20, 2002 | 03:11 PM
schindem's Avatar
schindem
Default Real Problem Here!!!
I have 3500 miles on my Z and have had it 10 weeks. The noise is still there and drives me crazy -god I hate these damn Brembos, Buyers of TRACKS- BEWARE!!! Go for the Touring w/leather and add an aero package, buy nice wheels and your's will be much better than the track! I am going to sell I think, just not as happy with the Z as I should be for this price!
Take notice, this is going to hurt the Track down the road!!!
late-
Old Nov 20, 2002 | 03:18 PM
wizeline's Avatar
wizeline
The brake noise is not impossible to fix. I had 3100miles on my track Z and I put the anti friction lube on the back of the pads.... no more noise. I am also upgrading to HAWK pads to cut back on the dust....these problems are minor and will not affect the Track Z in preformance or value!!!!!
The squeeking is not from misalignment or impropper wear, just the nature of a high friction pad on a large rotor!
I will have the new HAWK HPS+ pads here sortly and I will take photos of the replacement process to help other out. If you want, just e-mail me in a week or two and I'll post the process on the forums.
Calm down, call your dealer or locate some anti squeek lube at Auto Zone!!
Old Nov 21, 2002 | 07:43 AM
Nate's Avatar
Nate
Wow... I love the track and the Brembos.
These are true performance calipers, and from what I have heard, should also make brake maintenance easier (bleeding, pad replacement, etc).
If the only reason you got the track was for the looks of the painted calipers, maybe you are right
This is just a minor annoyance and I was just wondering if it went away on its own, or just needed some hard braking to break them in, or if they needed friction lube, or in the worst case scenario, shims or new pads.
Wizeline, so all you did was put a dab of antifriction lube from autozone on the back of each pad? What is the process for pulling the pads and how is different on the Brembos than standard calipers? Any tips? Keep me updated on the new pads as well
-Nate
LeMans Track
