Hotchkis Sway Bar Clunking
Originally posted by ksj
There is a TSB out for a clunking noise in the front going over bumps. All 2003's are covered by the TSB and the following VIN's for the 2004's:
APPLIED VEHICLES: All 2003 350Z (Z33)
2004 350Z (Z33) – see below Applied VIN / Date information
APPLIED VIN / DATE: Vehicles built before:
VIN DATE
JN1AZ3 4 D * 4T 151477 7/23/03
JN1AZ3 4 E * 4T 051103 7/23/03
JN1AZ3 6 D * 4T 102127 7/24/03
JN1AZ3 6 A * 4T 003223 7/23/03
Essentially the TSB says to loosen the front upper link bolts 1 full turn and then re-torque them to 37-44 ft-lb.
Hope that helps...
VIN DATE
Hope that helps...
Thanks man, thats a great help.....
I kept looking at that exact bolt thinking maybe it was the culprit.
ok thanks, i had looked at those two also because the aft one on the drivers side has a rubber washer thats floating around aimlessly. It just caught my attention, but didn't feel loose. Thanks, I'll jack it and try retorquing those two bolts and see what happens from it.
Sorry if I sound like an idiot, but I am confused. I just installed my front Hotchkis sway and it went in exactly the same way the other came out... the only differences to the stock set up are as follows:
1 - had to bend the alignment tabs
2 - Used different bushings (although they looked the same as stock and had the same 'key' bump on the top to fit in the stock metal bracket.
Why would the hotchkis bar act any different than the stock one (with regards to sliding or clunking)???
BTW - mine does not clunk.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
