Will sway bars help with this problem
Old Aug 5, 2004 | 03:41 PM
booger's Avatar
booger
Default Will sway bars help with this problem
I have headers on the car [G35coupe] and they have started to rub against the steering shaft when taking a right hand turn . I can feel it in the steering wheel and Ive seen where its rubbing on the header . Do you think sways will help with the flex and keep it from hitting the header ?....Bill
Old Aug 5, 2004 | 04:59 PM
Audito350Z's Avatar
Audito350Z
nope... swaybars do not minimize chassis flex, they help control body roll on the suspension...
the older version of the NISMO headers also rubbed on the stearing shaft... NISMO redesigned them to fix the problem... sounds like you need to go to BRM and tell them they need a redesign
Old Aug 5, 2004 | 06:49 PM
arizzee's Avatar
arizzee
Booger, alittle OT, but I've tried calling BRM and got no call backs. What's the trick or did you find some dealer?
Also, aren't BRMs unbadged Nismos? If so, I bet you've got the V.1 as mentioned.
Old Aug 5, 2004 | 07:15 PM
PhoenixINX's Avatar
PhoenixINX
Time to use a blue tipped wrench and put a dent in them.
Old Aug 6, 2004 | 05:24 AM
Audito350Z's Avatar
Audito350Z
the other thing you might try is an upper strut brace, like the one in the 350Z... there's a few aftermarket ones that fit the G56c
Old Aug 6, 2004 | 06:40 AM
booger's Avatar
booger
What do you mean....[alittle OT ? ] I got them from Azhitman...he works for them...you can find him at Nico forum.....On the Infiniti part
Old Aug 6, 2004 | 06:41 AM
booger's Avatar
booger
Ive seen the strut brace...but Ive never seen an under strut brace ?
Old Aug 6, 2004 | 10:05 AM
GPorsch's Avatar
GPorsch
An engine brace would help. To keep the motor from moving when you turn. I think Stillen is developing one.
Uriyo_
Sep 8, 2021 08:46 AM
hulkout
Apr 28, 2017 09:00 PM
