Suspension Set Up help...PLEASE !!!
Old Aug 15, 2004 | 08:28 PM
FarSeide's Avatar
FarSeide
Lightbulb Suspension Set Up help...PLEASE !!!
I have GT-7s on my Z and here is the setup:
Front: 19 x 9.5 (+30 Offset)
Rear : 19 x 10.5 (+24 Offset)
I just boght a set of Eibach Pro Kits and was wondering if my rear tires will rub the fender if I lower with Eibachs.
Does anyone have this particular set up ? Please help me...
Thanks
Old Aug 16, 2004 | 07:52 AM
Audito350Z's Avatar
Audito350Z
are you using 275/35-19 rear tires??? if so, then you should be ok... wider than that and you might rub...
I have the Eibach springs on my car and they are not so low that you compromise the wide tires. I had my 275/40-17 race tires with 17x9, ET35 wheels and I had plenty of room between the sidewall and the fender... so your wheel moved toward the fender 9mm shouldn't cause any problems.
PeteH
Old Aug 16, 2004 | 08:27 AM
Road Warrior's Avatar
Road Warrior
if my ups gal looked like that i'd be ordering shiz like a big dog
Old Aug 16, 2004 | 09:55 AM
FarSeide's Avatar
FarSeide
Thanks Peteh.. yeah my tires are 275/35/19 in the rear. So you think I should be ok then ? Its pain in the *** to put the springs on and take em off so i wnated to make sure... thanks
Old Aug 16, 2004 | 12:25 PM
DruDragzOn's Avatar
DruDragzOn
I have eibachs on with a 10.5 rear on 275 size tires no rubbing and my offset is +22.
Old Aug 16, 2004 | 01:27 PM
FarSeide's Avatar
FarSeide
is there a big difference between offset +24 versus offset +22 ? thanks everyone
Old Aug 16, 2004 | 03:29 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
2mm
you should be fine on Eibachs
