NEW from Cusco!!!!!!
Adam,
You mentioned that the cuscos use the stock bushing whereas the evos use the pillowball type. Sorry for the newb question but what's the difference? I'm thinking that the pillowball will be more responsive/sharper?
al503 - yes pillowballs will be much more responsive...and much nosier, transmitting more NVH to the cabin.
zwindsor - once they are in our hands, we'll have full details on our site
The monoball inserts will not produce any more road noise.
They will however be much smoother than the OEM bushings and will not have the flex an OEM rubber bushing has. THis will translate into crisper suspension tuning.
Cheers
BJ@350EVO.com
Cheers
BJ@350EVO.com
It took a friend and myself 1 1/2 hours to install the arms from 350EVO arms. The arms are superb and they fit like OEM.
The camber has much improved. Nearly perfect. I will get an alignment soon. The steering is super crisp and tight. No more noise than the OEM arms. Well worth the money. I would like to buy the sways from them... though the supplier seems to have dropped off the planet. Any word BJ?
Thanks.
Thanks.
Cheers
BJ@350EVO.com
Cheers
BJ@350EVO.com
[QUOTE]Originally posted by myG35zx
Thanks. [/QUOTE.]
Did your friend go with the pillowball or monoball? I would hate to have squeeks in my suspension
Thanks. [/QUOTE.]
The arms are perfect. No additional noise or noticable vibrations. The steering was improved and the adjustability is fantastic.
The arms have more than enough of adjustability. I found out that I used very little of the adjustment for the eibach springs. Way more was available. When/If i lower the 05 sedan, I will buy these arms again with no hesitation!
Hi BJ, wanted to check in on the status of adding caster correction to the upper A-arms. I really like the 350 Evo design, but in HI, we need EVERYTHING within spec to be "approved" as street legal.
Right now, my camber and caster are a little off. I'd be interested in picking up the A-arms as soon as it can fix both problems.
Let me know... Thanks!
Z1 Performance
Apr 26, 2004 09:42 AM
