Front and rear hub removal to access brake backing plates
It looks like the front and rear hubs on the Z are held in with 4 bolts each.
The rear hubs require a puller the fronts don't, correct?
If so, it looks like a simple job to remove hubs and modify the backing plates easily on the bench rather than on the car.
I want to do a nicer job than just hack things while mounted on the car.
Is this true, or is it more of a hassle than that, due to potential damage to wheel bearings etc.
I have pullers to do it.
Thanks.
Thanks.
I have had both front hub/bearing assemblies off my car (swapped from side to side actually). It is a simple job.
Be careful of the speed sensor on the rear and the little dust cover back there (white).
I seem to remember that one bolt was a bit hard to get to, but I managed to get them off with no problem.
Actually, it is a bit scary thinking that the whole front end rides just on those 4 bolts, so make sure to torque them properly when you put them back on. I have the manual downloaded somewhere if you need the torque spec for them.
I did not do the rear so I cannot help you there.
Ray
Ray
hardkicks
Sep 20, 2015 12:28 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
