Alignment Question...
Old Oct 23, 2004 | 11:10 PM
mbonanni1856's Avatar
mbonanni1856
Default Alignment Question...
If I went from 18" wheels to 19" wheels would I have to adjust the alignment on my car?
Old Oct 24, 2004 | 02:10 AM
KY350's Avatar
KY350
You can only adjust toe in / out unless you have an aftermarket camber / castor kit.
Do it - it should only cost about $20 and takes about 10min.
Old Oct 24, 2004 | 11:23 AM
mbonanni1856
So if I wanted 19" rims, but I wanted to put racing tires on the old 18" rims and switch them out for every race that would be a bad idea?
Old Oct 24, 2004 | 01:12 PM
basam350z's Avatar
basam350z
You don't need an alignment if you switch wheels, unless you dramatically change the circumfance of the tire.
Rule of thumb is for every inch you got up on the rim, go down 10 on the series of the tires (ie 225/45/18 to 225/35/18)
Old Oct 25, 2004 | 10:13 AM
mbonanni1856
Right on. Thanks.
Old Oct 27, 2004 | 11:16 AM
Zquicksilver's Avatar
Zquicksilver
Got new wheels and this is my question to you guys. The tire diameter in the front is the same. The rear tires are around .75" larger now...
I will be rotating tires out every winter season. Stock w/snow tires Thanksgiving to Easter roughly.
Should I get those re-aligned every season or not?
Paul.
Oct 16, 2015 07:34 PM
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
