Suspension springs & Dampers
Old Nov 15, 2004 | 07:12 AM
PSR Performance's Avatar
PSR Performance
Default Suspension springs & Dampers
I am reading alot of posts pertaining to spring and damper questions. Let me just throw this out there.
Vogtland Sport springs and Tokico "D" Spec dampers
Probably one of the best combination set ups for the money. Lowering between .7 and 1.0" and finite adjustments to the damper provide some pretty decent handling.
Old Nov 15, 2004 | 07:31 AM
350ZOWNZ's Avatar
350ZOWNZ
what are the specs on the vogtland springs? like spring rates? they a linear or progressive spring?
Thanks
Old Nov 15, 2004 | 07:41 AM
PSR Performance
Thanks
Spring rate for the Vogtland kit are as follows 62 N/mm (350 lbs/in) front and 74 N/mm (420 lbs/in). Spring rates in the rear will be higher due to the motion ratio, spring rate to wheel rate therefore it is higher than the front.
They are linear in rate front and rear
Thanks.
350Z_Al
Oct 29, 2020 07:44 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
