zaino gloss spray?
Old Nov 1, 2002 | 09:07 PM
ares's Avatar
ares
Veteran
Default zaino gloss spray?
what am I doing wrong? I did my zaino bit, great stuff, but the spray always seems to leave streaks. since it offers no protection except its "high gloss", and it leaves me with cloudy residue. I am done with it untill someone can tell me Im doing something wrong.
the car looks spectacular after waxing, then I spray this stuff on and get cloudiness. any suggestions?
Old Nov 2, 2002 | 07:26 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I assume you mean the Z-6? Don't spray it directly on the car, just on the applicator, then wipe it on THINLY. Then DO NOT allow it to dry! You have to wipe it off immediately. If it dries at all you should apply more on top and wipe THAT off immediately.
If you have already done all that, then I'm not sure what the problem is. Maybe Sean or Brad can help.
Old Nov 2, 2002 | 07:32 AM
ares's Avatar
ares
Veteran
hmmm, but its like I wipe it on thinly, and about 5 inches behind the pad, you can see it evaporate away... and its dry and left streaky.
Old Nov 2, 2002 | 08:00 AM
ezee's Avatar
ezee
You might be using too much Z6, it only takes a little bit do do the whole car, try using less, and don't let it dry, buff off right away.
I spray right on the car, not on an applicator (this is what Zaino recommends), and I use a microfibre towel to buff (no lint).
When I finish the car with a coat of Z6 after several coats of Z2, my Z shines like a diamond. Good luck.
Old Nov 2, 2002 | 08:03 AM
LowFuel's Avatar
LowFuel
Set the nozzle to give the finest, least amount of spray you can. Then spray just one puff on a section of car and immediately wipe it off with a cotton towel. You will notice the towel resists a bit at first, and as you wipe it gets smoother and smoother until it finally just glides over the car - thats when you stop and go to another section. Also fold the towel constantly so you're always using a relatively dry bit. Switch towels if it starts to feel a bit damp.
I use it all the time and have never had any cloudiness. In fact the Z6 spray is by far my favorite and most used Zaino product.
Old Nov 2, 2002 | 08:43 AM
ares's Avatar
ares
Veteran
well, Im gonna wait a week before waxing again(I thought I read that was best somewhere. eh whatever.
and Ill give the spray another shot then and do as you reccomended. hopefully it will work better this time.
Old Nov 2, 2002 | 09:54 AM
LowFuel's Avatar
LowFuel
btw you keep saying "Waxing" but I assume you're talking about using Zaino polish, right?
You definitely dont want to put Z6 on top of a wax or really anyhing other than Zaino, otherwise it will definitely cloud up.
Old Nov 2, 2002 | 11:07 AM
Brad4rdHay's Avatar
Brad4rdHay
Default Low Down on Quick Detailers
(BTW, Zaino isnt a polish, its a polymer sealant, but most people just say im waxing with zaino...cause its closer to a wax than a polish.)
Use the spray sparingly on a perfectly clean finish, I.E. after washing or inbetween coats of sealant. But, you want to use enough when the car is dusty, making sure that you have enough lubrication to wipe off the dust saftly. THIS is why I recomend you buy a cheaper quick detailer such as Meguiars Final Inpsection (tan bottle, not red), as you can use it liberaly without spending lots.
Always apply to a cool finish, wipe with a clean towel, then buff with the other side, repeat this, working panel by panel (don't work in big sections).
Old Nov 2, 2002 | 01:40 PM
Kevin Overall's Avatar
Kevin Overall
You do not use the Zaino applicator pad (cotton cover foam pad) to apply nor remove the Z-6, that is the problem.
With Z-6, less is more. You should be able to detail the entire car 32 times with one bottle of Z-6.
You can either mist a 2 foot square area of the paint or mist the towel and then wipe on the paint.
You will notice at firs the paint will have a thin wet layer of Z-6, since Z-6 is heat activated, with multiple passes of the cotton towel and a couple flips of the towel the Z-6 will quickly evaporate and one more pass will leave a completely clean and reflective paint surface.
Most of my customers who are new Zaino users try to douse the paint with way too much Z-6 right off the bat.
I just dribble a few drops of Z-6 on a small spot and then spread it out evenly.
You can only effectively Z-6 about a 2 foot section at any give time.
Old Nov 2, 2002 | 05:37 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Kevin: Are you saying you don't "wipe it in" after you spray it on i.e. just spray on and wipe it off? I have been using the applicator all along. In fact, whenever I buy the Z-6, they always send me another applicator with it. I have always followed a protocol passed down by the ancient Zaino gurus and it has always looked really good. I'll have to try it that way now!
Old Nov 2, 2002 | 05:45 PM
Kevin Overall
Sal Zaino and most all Zaino distributors like myself include a free #314 4x5 Zaino Bros' Custom Polish Applicator (100% virgin cotton) with each order over 25.00 but this applicator is only to be used with Z-1, Z-2, Z-3, or Z-5. Z-6 would not work very well at all if you try to spread it around with the tiny Zaino pad.
Just spray on and wipe off, you never wipe it in that much.
I have been a rep for the company since about 1998 or so and this is the first time I have ever heard of anyone trying to use the Z-6 using the polish applicator pad.
Old Nov 2, 2002 | 05:56 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
SO, what are you saying???? Are you saying I'm WEIRD or something??? HUH??? Am I like FUNNY? Do I make you laugh??? HUH?
Sorry, got a little carried away. Hold on, let me take my medication.....................glug glug glug..... aaaaaaahhhhh
There, that's better..............
Now where were we......
Old Nov 2, 2002 | 06:03 PM
Kevin Overall
Well at least you will have a fresh blue berry smelling breath after drinking your Z-7
Old Nov 4, 2002 | 08:40 AM
Gadgetman's Avatar
Gadgetman
Default 20 yrs of Zaino
That's about how long I've been using it. Yes when they initially had ONLY ONE product, it was "Show Car Polish".
Anyway, I have not had problems using a cotton applicator when applying the Z-6 directly followed by cotton towel wiping... particularly when doing spot cleaning etc. However, most times when doing large area or overall car, I'll just spray an area lightly and then rub & wipe with dry cotton towel.
Old Nov 5, 2002 | 01:20 PM
zPilott's Avatar
zPilott
Well, I dont know if they are actually considered a "polish," but all the Zaino bottles (Z2, Z3 and Z5) call the product a polish.
Old Nov 5, 2002 | 02:26 PM
Kevin V's Avatar
Kevin V
Think of Zaino as a "synthetic polymer", since it doesn't actually contain wax or abrasives.
Old Dec 12, 2002 | 01:47 PM
gfunk808's Avatar
gfunk808
Someone indicated that u could use a quick detailer spray on a dusty car...
is it okay to use detailing spray on a car that has not been freshly washed?
or is it mainly for a pretty clean car that has some smudges or fingerprints, etc.?
Old Dec 12, 2002 | 02:22 PM
VaGentleman's Avatar
VaGentleman
Lot's of posts here...mmm..from Zal.."if you use a little and it streaks..that's too much!"
Use just a hint of Z6...I do..and what results!!
VG
ps...waiting for my new wheels/tires *stolen*..I still stop by the dealer to Zaino
Old Dec 12, 2002 | 09:29 PM
NismoEagleRock's Avatar
NismoEagleRock
kevin,
so, after reading one of the above replies, is it not a safe practice to use z6 on a finish that was not washed prior to application? here is my detail procedure when i do not have time to wash the car (and when the car is not excessively dirty): i use a california car duster (which works very well, might i add) to first brush off the dust or debris on the car, and i then detail the car with light sprays of the z6. this process works pretty well, although i tried it a couple of times. but, is this not a good practice? please let me know oh wise zaino one.. haha..
thanks
Old Dec 13, 2002 | 03:50 AM
Kevin V's Avatar
Kevin V
If a car is "dirty" you don't want to be sliding dirt all over the finish, giving swirl marks and possibly scratches, regardless of what product you use.
If the car is mearly dusty, use the california duster and some Z-6 and it looks like you just polished it. I do it all the time.
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
tm9293
Wheels Tires
Sep 11, 2015 02:45 PM
