Removal of Dress Shoe Marks
Old Jun 21, 2005 | 10:55 PM
NTRIGUE's Avatar
NTRIGUE
Default Removal of Dress Shoe Marks
This stuff is impossible to get off the sideskirts! I even had a difficult time with CLAY! I used some products GOO-GONE a Professional Acetone for wax removal...
Old Jun 21, 2005 | 10:59 PM
JamRWS6's Avatar
JamRWS6
Be careful with goo gone....because it will remove paint.
I'd try a very fine abrasive to remove those marks (you are talking about the rubber from the heel of dress shoes, right?)
Old Jun 22, 2005 | 07:32 AM
mdracer76's Avatar
mdracer76
Goo gone removes paint? I guess my car should be bare metal by now with all the vinyls going on and off of it.
An abrasive, no matter how mild, SHOULD NEVER be used on your cars paint unless its the final resort.
I'd try bug and tar remover as well... and be more mindfull when entering and exiting your Z.
Old Jun 22, 2005 | 07:51 PM
JamRWS6's Avatar
JamRWS6
Yeah, instead of using an extremely mild abrasive that could not remove your clear by using it everyday...let's go ahead and use Goo Gone that will remove paint. Makes sense to me
I think if you actually had any experience with the marks he is talking about you would know that a chemical is not going to remove the scuff from a rubber heel. Even if it did there would still be an abrasion left that a mild polish is needed. This is a finishing polish not a rubbing compound.
But then again....just go ahead and keep rubbing with the Goo Gone and cry later after you start taking off paint...because then you know your clear really is gone!
Old Jun 23, 2005 | 05:44 AM
mdracer76's Avatar
mdracer76
I have INGs side skirts, and my girl has left those rubbery scuff marks on that side many times. I've used both Bug and tar remover (worked well) and good gone (also worked).
I've never heard or seen goo gone remove clear in my 10+ years of maintaining show cars. I'm sure ANY chemical, mixture would remove paint if left on the surface for an extended period of time, However in this case, where your trying to remove an isolated mark, I'm sure that this member has the common sense not to leave the product on the paint overnight (read: extended period of time) Use goo gone or bug and tar remover, then wash and rinse the area where it was applied.
In my exp. any abrasive, even a polish should be avoided unless necessary. What a polish is doing, even a very mild one, is indeed removing a minor amount of clear coat. That’s how the 'mark' disappears. your evening the clear around the area of the scuff to make it less noticeable.
But hey.. its his/her car.. were only here to try and offer sound advice.
Old Jun 23, 2005 | 07:36 AM
350UZSB's Avatar
350UZSB
I usually use Mister Clean Magic Eraser for all scuff marks...but it sounds like your marks are a little more hardcore
Old Jun 23, 2005 | 09:48 AM
NTRIGUE's Avatar
NTRIGUE
Turtle Wax Bug & Tar worked very well!
I left it on the stains for 60 seconds and wiped with very little force. I regularily use Goo Gone in my engine bay to remove 'Track Muck' and have seen no change in paint (ie discoloration/transfer to applicator/fogging) it just wasn't up to this task.
Old Jun 24, 2005 | 08:24 AM
jrotaryb's Avatar
jrotaryb
DO NOT use the magic eraser on paint. It's a pretty harsh product that I believe has some content of bleach in it!
Fresh shoe scuffs come out of my sideskirts with a little quick detailer easily - I use a solution of water in a spray bottle and about 2 oz of Klasse AIO as a quick detailer.
Old Jun 26, 2005 | 09:09 PM
JamRWS6's Avatar
JamRWS6
I'm just speaking from experience with the goo gone...and a bad experience at that. The goo gone had not been sitting on the paint for even a minute.
I guess as long as you don't rub hard or leave it on very long you'll be OK...I personally don't even use it anymore.
Of course each mark would have to be treated accordingly.....there are some marks that just won't come out with a tar/bug remover product
Old Jun 26, 2005 | 10:02 PM
bio911's Avatar
bio911
Paint prep.. takes it off like it is nothing
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Fixxxercask
Nov 9, 2015 11:10 AM
nanotech
Oct 2, 2015 05:02 AM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
