Zaino Z-PC Fusion - Any Reviews Yet?
Old Jul 5, 2005 | 12:25 PM
bixby's Avatar
bixby
Default Zaino Z-PC Fusion - Any Reviews Yet?
Has anyone tried this yet? Dr Bonz? McDuck? anyone?
Introducing Zaino Fusion - Dual Action Paint Cleaner Swirl Remover
• Safely removes minor scratches, swirls, oxidation, wax buildup and other blemishes
• Features the world's first true self-dissolving, fused tri-particulate, diminishing abrasive system
• 100% compatibility with all painted surfaces and Zaino paint products
• Water-based formula means no mess, no staining, and easy clean up - no fillers or oils
• Can be used in sun or shade on cool surfaces
• VOC compliant
• Perfect your paint with Zaino Z-PC Fusion
NOTE: Zaino Z-PC Fusion IS ABRASIVE and should only be used when necessary. Z-PC Fusion is not intended for frequent use.
For years, visual imperfections such as swirl marks, scuffs, scratches and buffer holograms were the scourge of perfectionists everywhere. They infected vehicles without any discrimination - show cars, daily drivers, imports, domestics and custom vehicles all suffered. But worry no more - Zaino, the world's leader in paint care technology, has the antidote for all of your paint ailments: Zaino Fusion Dual Action Paint Cleaner Swirl Remover ("Z-PC").
Featuring the world's first (and only) true, self-dissolving, fused tri-particulate, diminishing abrasive system, Zaino Z-PC Fusion is just what the paint doctor ordered for your vehicle. Whether your paint is suffering from spider-webbing, minor scuffmarks, or a fully developed case of the swirls, Zaino Z-PC Fusion has the cure. And best of all, it works equally well when used by hand or machine, making it as versatile as it is effective!
Thanks to Zaino's advanced, fused tri-particulate, self-dissolving diminishing abrasive system, swirls and other defects are safely removed from your vehicle's paint. The ultra-intelligent abrasives gently and carefully knockdown high spots on your car to reveal an extremely smooth, super-reflective, mile-deep shine. Swirl marks and other blemishes will literally disappear before your eyes, and they'll stay away - Zaino Z-PC Fusion contains no fillers or oils.
With Zaino Z-PC Fusion, you'll be amazed by how deep, glossy, clean, and blemish-free your paint looks, and you'll love the compatibility that it provides. Unlike other paint prep products that are typically loaded with cheap oils and fillers, the water-based formula of Zaino Z-PC Fusion requires no washing afterward - just apply and remove Zaino Z-PC Fusion and go straight to applying your favorite Zaino protectant. Further, there's virtually no effort required to apply and remove Zaino Z-PC Fusion. Just wipe it on, work it in (either by hand or machine) and wipe it off.
Zaino Z-PC Fusion is perfect for any type of paint - from single-stage paints to clear-coated finishes to gel-coats, Zaino Z-PC Fusion will bring out the best in your paint. Metallics will sparkle! Pearls will pop! Reds will scream, "Pull me over," and your black paint will never have looked so smooth. It's perfect for domestic cars, European cars and imports. So whether you're driving a super-exotic performance car or just running the kids around town, be confident that no other paint cleaner is as advanced, effective and easy to use as Zaino Z-PC Fusion is.
So say good-bye to swirl marks, scuffs, spider-webbing, and other annoying paint defects. Zaino Z-PC Fusion takes your paint to a whole new level - one that's certain to drive other enthusiasts insane with jealousy!
The Z-PC bottle contains 8 fl. ozs. (236 ml.)
APPLICATION INSTRUCTIONS
Note: For best results, use on a cool surface, out of direct sunlight. Product may be used in the sun or on a hot surface, but more dusting and minor streaking may occur.
  1. Wash and dry your vehicle as normal.
  2. For HAND use: apply a small amount of Zaino Z-PC Fusion to a cotton or foam applicator pad (draw an "X" from corner-to corner of your pad). Work a small area (no bigger than 2' x 2') with the Zaino Fusion, using firm motions. Work the product for as long as necessary - stop to occasionally check your progress. Circular motions may be used, but always finish with front-to-back or up-and-down motions. When satisfied with progress, continue to step 4.
  3. For MACHINE use: Can be used by random orbital or (for experienced users) rotary. Select a moderate speed (RO - 4.5; Rotary - 1200rpm) and an appropriate cutting or polishing pad. Apply Zaino Z-PC Fusion to the buffer pad in a "star" pattern. Start machine slowly to reduce sling. Work a small (2' x 2') area with moderate pressure until satisfied with results.
  4. Buff the area clean with a soft, lint-free, non-marring towel. If satisfied with the results, proceed to next section. If more buffing is required, repeat either step 2 or 3. Problem areas like door handles (where keys often scratch) may require a few applications for best results.
  5. When done, apply either: Zaino ZFX enabled Z-2 PRO, Z-3, or Z-5 to the surface for a long lasting, great looking shine that will lock-in the results of your work with Zaino Z-PC Fusion.
Tip: If more "bite" is desired, you can mist a slight amount of clean water (from a spray bottle) while using Z-PC Fusion. The water will interfere with the buffers that encapsulate the abrasives and will produce a slightly stronger result. Water can also be used to minimize dusting when using a machine buffer (random orbital or rotary).
FREQUENTLY ASKED QUESTIONS
Does Z-PC replace Z-5?
No. Z-5 is not an abrasive and can be used as often as you like. Z-PC contains diminishing abrasives that are not intended for frequent use on paint finishes. Z-PC also does not have any protective qualities, so you must use a Zaino product like ZFX enabled Z-2 PRO, Z-3, or Z-5 for durable and long lasting protection.
When would I use Z-PC verses Z-5?
We prefer to attempt the least or non-abrasive process prior to moving on to Z-PC. If after 1 or 2 coats of Z-5, you are not satisfied with the surface condition, you will need to move onto Z-PC.
Will Z-PC remove Zaino Z-2 PRO, Z-3, or Z-5?
Yes. By it's very nature as a diminishing abrasive, Z-PC breaks down the finish including Zaino polishes.
Old Jul 5, 2005 | 06:38 PM
Kevin Overall's Avatar
Kevin Overall
I have been using test samples for quit some time, and I know have in stock the production version. Works wonders with a foam pad and the Porter Cable, and best of all you do not have to wash with Dawn after its use like you did with the 3M before Zaino applicaiton as the ZPC and Zaino have bases that are compatiable.
Old Jul 6, 2005 | 07:40 AM
bixby's Avatar
bixby
Thanks Kevin! So I just wash with Z7 then go at it? Also, I have an orbital buffer, is that the same as a Porter Cable?
Old Jul 7, 2005 | 11:09 PM
JamRWS6's Avatar
JamRWS6
I wasn't all that impressed with the Z-PC. Using a green pad on a black car it actually introduced micro-marring into the surface and holograms. Using the blue pad removed this and a damp towel was needed to remove the remaining polish.
The Menzerna Final Polish II is easier to use and gets better results for me. I don't mind doing an alcohol rub down before the Zaino process.
hulkout
Apr 28, 2017 09:00 PM
nanotech
Oct 2, 2015 05:02 AM
carid
Misc.
Sep 10, 2015 06:16 AM
robbyn
Aug 2, 2002 08:41 PM
