Quick zaino question
Old Jul 23, 2005 | 09:22 AM
Westby's Avatar
Westby
Default Quick zaino question
It's in the low 90s right now, just finished claying. Question is outside under the sun without ZFX or inside with ZFX which is the way to go.. Oh and Was going to use some blue coral scratch remover, if i did do I need to re wash/clay before I put the zaino down?
Thx, take it easy.
West.
Old Jul 23, 2005 | 11:22 AM
lovetoclown's Avatar
lovetoclown
If this is your first coat of Ziano, you need to use the ZFX either way. it helps to bond to the paint. The only way you do not need the ZFX is if you use the Z-1 polish lok. If you are not going to use the Ziano scratch remover, then I would just rewash the car before polishing it with the ziano. I have been polishing my car outside and it works GREAT. Good luck.
Old Jul 25, 2005 | 01:42 PM
sisco534's Avatar
sisco534
With Zaino you can wax in 90+ degrees and will not hurt a thing....it is the best. I have 3 coats on. Once a week I go to the car wash and rinse it off that is it then I head down interstate 24 80 or 90 dries perfect no water spots this stuff is the bomb.
Old Jul 26, 2005 | 05:45 PM
Kevin Overall's Avatar
Kevin Overall
Zaino can only bond and be properly applied to bare paint, if you use a scratch remover OTHER than the Zaino ZPC you must wash that area with Dawn or use some other kind of wax cutting prep solvent before Zaino application.
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
