Steel wool on winshield
Old Dec 11, 2002 | 09:08 AM
silverz's Avatar
silverz
Default Steel wool on winshield
Does anyone use steel wool to clean there winshield before they use glass cleaner? Does it scratch? I guess if you chose to use the steel wool you would have to use the ones with soap already in them - right???
Thanks.
Old Dec 11, 2002 | 04:48 PM
nosuchsol's Avatar
nosuchsol
I don't think I would touch my car with metal. What would be ground into the window that would warrant using steel wool? I could see how it would scratch!!
Old Dec 11, 2002 | 06:46 PM
Goober's Avatar
Goober
Charter Member #57
I've used steel wool with a water/vinegar solution on many cars without any problems trying to get rid of hard water deposits. I never used more than a medium coarseness on the steel wool. It won't scratch the glass, just let the steel wool do the work and don't force it in too much.
Old Dec 11, 2002 | 07:18 PM
krinkov's Avatar
krinkov
little trick for hard water spots on glass, chrome cleaner/polish, works great
Old Dec 11, 2002 | 09:48 PM
nosuchsol's Avatar
nosuchsol
Interesting... it just sounds like it would scratch. I'll stick to my 3M fine swirl mark remover for talking out water spots. =)
Old Dec 11, 2002 | 09:59 PM
krinkov's Avatar
krinkov
nope, completely non abrasive,
Old Dec 12, 2002 | 06:37 AM
FlaPhil's Avatar
FlaPhil
SilverZ, what are you trying to fix?
Old Dec 12, 2002 | 07:55 AM
silverz's Avatar
silverz
Default Steel wool....
Actually, I 'm not trying to fix anything. Someone told me that if you use steel wool before you use glass cleaner, you get a much cleaner/clearer winshield. He had said that it will get bug, sap etc.. off that regular glass cleaner won't remove. I just wanted to try it (if it's safe) to see if there is a diference. Thanks for the input.
Old Dec 13, 2002 | 10:30 AM
zwindsor's Avatar
zwindsor
Twisty addict
You can use steel wool without a problem. It's imperative though that you use only "0000" grade wool. Anything courser may scratch. And like it was said ealier let the wool do the work.
Old Dec 13, 2002 | 10:37 AM
nosuchsol's Avatar
nosuchsol
ohhh... you have to use the pansy steel wool... yah, I was thinking the manly construction worker steel wool. =P I'm such a dork.
Old Dec 13, 2002 | 08:15 PM
d8abusa's Avatar
d8abusa
Don't do it! Even if the glass doesn't scratch you will get fine particles of steel all over your car. Eventually it WILL rust and leave stains in crevices and cannels where you can't can't get to.
I learned the hard way....consider it a gift.
Old Dec 14, 2002 | 06:14 PM
zwindsor's Avatar
zwindsor
Twisty addict
If you use it with the vinegar/water solution the particles stay on the glass and won't fly around. Then just wipe off. Of course you should always be careful not to make a mess.
sales@czp
Sep 23, 2019 03:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
