need help with interior detailing...
Old Oct 10, 2005 | 05:45 PM
steveiZdaman's Avatar
steveiZdaman
Default need help with interior detailing...
i used this vinyl cleaner on the dash and stuff and while spraying it on my rag it went on my door pannels and like now all u see is spots on my pannels...what do u recommend to fix this?
thanks
Old Oct 10, 2005 | 06:00 PM
Jamey1E's Avatar
Jamey1E
Default Thank U!
Yes would someone please help out, (I thought it was just me) but i've tried several different cleaners and it all end's up the same spot's... What do you guys use?
Old Oct 10, 2005 | 07:46 PM
DavesZ#3's Avatar
DavesZ#3
A common problem. You'll need to take a cloth and some slightly soapy water to wash the door panels to remove whatever you put on them.
The trick to putting anything on the door panels is to spray it on a cloth and work it into the cloth a little then rub it on the door or other interior panels. That help to prevent the blotchiness. If you spray anything directly onto the interior panels, it will spot or have that blotchy look.
Old Oct 10, 2005 | 10:04 PM
steveiZdaman
it bothers me so much when i look over at the door....i gota try to fix it this weekend
thanks
Old Oct 11, 2005 | 04:37 PM
Jamey1E's Avatar
Jamey1E
Default Thanks
Thanks alot I thought about trying that, but wasn't sure...
Old Oct 11, 2005 | 04:58 PM
DavesZ#3's Avatar
DavesZ#3
No problem guys. A little soapy water won't hurt. Don't make it too soapy as it might leave a residue. If it does require more soap to remove whatever you've got on it, you can always wipe it down with plain water to clean the soap off.
My personal recommendation for a treatment on the interior surfaces in 303 Aerospace Protectant. Not too shiny or greasy. Very good protection.
Old Oct 11, 2005 | 05:09 PM
ASTIG_Z's Avatar
ASTIG_Z
Yeah, I havent put any chemicals in the car's interior. Just good ol water and a clean rag.
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
