Converting Bench Grinder To A Polisher
Old Dec 30, 2005 | 05:19 PM
atlsupdawg#2's Avatar
atlsupdawg#2
Default Converting Bench Grinder To A Polisher
Didn't know if this was the right place to post but figured the topic relates to detailing..
Anyway, I have a nice 3/4HP bench grinder I've had for a couple years and I want to convert it over to a polisher. The shaft on the grinder is short and I would like them a little longer. Can this be done? If so, how would I go about doing it?? Wanted to see if anyone here knew before I start breaking this thing open..
Old Dec 30, 2005 | 08:24 PM
Are you sure this is a good idea? An oscillating polisher rotates back and forth to prevent possible paint “burn.” The bench grinder motor simply rotates.
Old Dec 31, 2005 | 07:20 AM
DavesZ#3's Avatar
DavesZ#3
Are you talking about something like one of these?
Those things weight a ton. How are you going to be able to safely manipulate that around the surfaces of a car?
You could get a threaded coupler that would screw on the shaft and you could screw a longer threaded shaft into the other side. I just don't know if all the trouble would be worth it.
Just go to Lowes and spend the $109 and get the Porter-Cable 7336SP:
http://www.lowes.com/lowes/lkn?actio...6SP&lpage=none
Old Jan 1, 2006 | 05:36 PM
atlsupdawg#2
DavesZ#3,
Yeah, I have one of those but I don't mean to polish the car with...LOL
I should've been a little more clear. I wanna start polishing aluminum, stainless, etc. The shaft is just so short compared to what they sell in the Eastwood catalog for $399. I thought I'd be able to convert my bench grinder over to a polisher since I hardly use it for anything else.
Old Jan 1, 2006 | 05:46 PM
DavesZ#3's Avatar
DavesZ#3
Whew! You had me worried there for a minute.
Then you definitely try the threaded coupler. I did something similar a couple of years ago. I bought this coupler at Home Depot. It was about 1½" long, hex sided piece with a hole drilled and tapped through it. It would screw onto a drive shaft then I could screw a longer threaded rod into the other size of the coupler.
Here's an example of what I'm talking about...
http://www.strongtie.com/products/ats/ats-couplers.html
Old Jan 2, 2006 | 07:46 AM
atlsupdawg#2
Thanks Dave...Any ideas on a shaft to buy? I think the buffing wheels form Caswell require a 1/2" dia. shaft
Old Jan 2, 2006 | 08:16 AM
DavesZ#3's Avatar
DavesZ#3
I looked at the Caswell stuff when I was attempting to polish a plenum but never bought it:
http://www.caswellplating.com/buffs/alpolkit.htm
Their pieces come with what looks like 1/4" shafts so they would fit a drill or something similar. That won't work for the setup you're trying.
You might want to get a chuck that would fit the shaft of your grinder then you would be able to mount the Caswell tools in the chuck.
Old Jan 2, 2006 | 04:24 PM
Originally Posted by atlsupdawg#2
I wanna start polishing aluminum, stainless, etc. .
LOL. I was wondering how are you going to polish a car with a 30 pound grinder.
Old Jan 3, 2006 | 05:49 AM
atlsupdawg#2
LOL... I'd be out there looking like Steve Martin in "The Jerk"
Old Jan 3, 2006 | 05:11 PM
schweatty's Avatar
schweatty
from what ive been told, an angle grinder (that looks like a sander/polisher) should not be used to polish your car. a grinder is too fast and will increase the likelihood of burning into the paint. get a porter cable. theyre fool proof and only about a $100 at Lowe's
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
