which wax/polish works best with black?
No - continue to work by hand and if you're not getting the results you want or you find it's too much work then it might be time to think about a PC. Don't sweat paint removal too much - unless you do something monumentally crazy it's actually pretty difficult to polish too much clear coat away by hand or with a PC.
Originally Posted by aleok
thanks, so how do i figure out if i need to get a PC or just try by hand? should i just try by hand and if it don't work then get a PC, will that be bad since i've already started to remove some of the clear coat?
If you're not comfortable with this, or aren't getting results, take it to a pro.
Lowes. It's $109, $99 if you use the movers coupon. The model is 7336 (or 7427), they are the same thing except the 7336 has a larger counterweight, so either is fine.
If you don't have a lowes nearby you can buy it online at a number of detailing outlets.
Tochigi_236
Sep 27, 2015 03:40 PM
