undercarraige rust
Old Feb 13, 2003 | 08:15 PM
scottlewis's Avatar
scottlewis
Unhappy undercarraige rust
With all the salt on the roads here on the east coast I want to give my Z an undercarriage wash but I only want to do it by hand. (I don't trust carwash.) I can't get a hose under car. Is there any hose attachment that would help me to do this or do I just breakdown and run it through the car wash? Replies most appreciated.
Old Feb 13, 2003 | 08:20 PM
afr0puff's Avatar
afr0puff
1. Those rainbow type water sprinklers. Just slowly drive over one of them.
2. The Euroblaster. That's what I use. It also has a soap dispenser so it sprays soap water too. It has a semi angled nozzle which makes it easy to get the bottom. But I think I'm going to get those tire ramps to make it even easier.
Old Feb 13, 2003 | 08:41 PM
ares's Avatar
ares
Veteran
yup, Id say park over a sprinkler, spray type or any type really should do it, as long as it fits under your car. or... if your cheap and handy with a drill, grab a long peice of PVC pipe, and drill lots of holes in it. put a hose fitting on the end, cap the other side. now you have a nice spray for under your car. if you have access to a high pressure tap, even better.
Old Feb 18, 2003 | 06:22 PM
Z'd's Avatar
Z'd
PVC is a great idea! Personally, I took a 10' section of garden hose, mounted it to a 1X4, capped one end, drilled some holes vertically and then attached a quick connect.
Then, just start at the front and slowly move it to the back. Our water pressure isn't great, but the spray still hits the ceiling if it's not under the car. Total cost < $5
Old Feb 18, 2003 | 07:01 PM
ares's Avatar
ares
Veteran
yeah, make the holes one at a time untill the pressure starts to get too weak. easier to drill more than patch the old ones.
Old Feb 19, 2003 | 04:54 AM
Jewelz350's Avatar
Jewelz350
I just used a floor jack and jacked up one side of the car then powerwashed.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Suffolk350z
Sep 13, 2015 02:43 PM
yobri
Apr 26, 2005 03:27 PM
