GUM on my Z
Old Jul 17, 2006 | 08:38 AM
Z_rican's Avatar
Z_rican
Default GUM on my Z
Some punk stuck some gum on my rear right fender area. They stuck it there pretty good. I noticed it yesterday and i tryed to get it out but I just made it worst. What do you guys recommend for me to take this gum off my ride? I have some goo gone somewhere, will that work?
Who ever put that gum on my car is a real hater. I just had my car washed and waxed on Saturday.
Old Jul 17, 2006 | 09:01 AM
EdJ's Avatar
EdJ
Try Meguiars Scratch X, its a small abrasive compound that will turn into a polish after a while of rubbing it in the area you are applying it. Use a microfiber towel when applying it. Hope it helps.
Ed
Old Jul 17, 2006 | 09:06 AM
superchargedg's Avatar
superchargedg
Damn Noobs
wd-40 should work also.
Old Jul 17, 2006 | 09:11 AM
VO...'s Avatar
VO...
Administrator
regular wax will get it off, or that stuff called "goo gone" will work perfectly.
Old Jul 17, 2006 | 09:32 AM
Hyundai350zFWD's Avatar
Hyundai350zFWD
use peanutbutter and ice cubes to remove it.
there was an episode on the simpsons where lisa got gum stuck in her hair. they recommended peanutbutter and ice to remove it.
Old Jul 17, 2006 | 10:29 AM
two words: pop charger.
Old Jul 17, 2006 | 02:36 PM
Suvlaki's Avatar
Suvlaki
+1
Old Jul 17, 2006 | 02:42 PM
aznmojo's Avatar
aznmojo
brake cleaner takes it all off
Old Jul 17, 2006 | 02:54 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Wow, thas one hell of an answer, especially for first post. Does anybody know why he got banned already? This one post of his isn't enough to get him banned I wouldn't think.
Old Jul 17, 2006 | 02:56 PM
LSRoadster's Avatar
LSRoadster
Maybe because he is from Lybia?
Old Jul 17, 2006 | 03:04 PM
roast's Avatar
roast
Please, do not feed the trolls. (ignore them).
Old Jul 17, 2006 | 03:06 PM
3hree5ive0ero
Retired Admin
No dude, there's no troll to feed. He's banned, see? I was just asking if anybody knew what happened. I just can't imagine what you'd have to do to get banned after 1 post, which isn't even that bad. Oh well.
Old Jul 17, 2006 | 03:11 PM
ZRider07's Avatar
ZRider07
Haha indeed. +1
Old Jul 17, 2006 | 03:34 PM
mdracer76's Avatar
mdracer76
He/she/it was prolly someone that had recently been banned, and signed up with a new name. A mod may have seen that he has the same IP, and... booted him again.
Old Jul 17, 2006 | 03:50 PM
Sk8fe's Avatar
Sk8fe
No. 7 Bug cleaner
I would be very careful with "goo gone" or anything "abrasive". Goo Gone removed the paint off of my garage floor with barely any wiping (gum stuck to garage floor). I would recommend the bug/tar/sap cleaner.
HTH
Old Jul 17, 2006 | 03:54 PM
mdracer76's Avatar
mdracer76
I've used Goo-Gone on my finish before, and was sure to rinse thoroughly, the area that you aplly the Goo-Gone.
I would not let it sit and bake, but apply the Goo-Gone, and with a microfiber towel, rub gently. Repeat. Then rinse the area with water. Repeat until the gum is gone. Rinse the effected area again. and wax.
Old Jul 17, 2006 | 04:19 PM
Sk8fe's Avatar
Sk8fe
OK, good to know. Thanks!
Old Jul 17, 2006 | 04:43 PM
Z_rican's Avatar
Z_rican
Pop charger huh??? Thanks for the advise guys.
Old Jul 17, 2006 | 04:47 PM
zeebeda's Avatar
zeebeda
i would use goo gone. that's what i used to remove the left over glue after de-badging my RSX-S.
It worked fine, and took off no paint at all.
Old Jul 17, 2006 | 04:53 PM
Z_rican's Avatar
Z_rican
I also used goo gone to remove the 350z emblem in the rear. It worked fine. I'll see what I can do. I cant believe that some ***hole would do this crap.
