How to clay bar
Old Sep 14, 2006 | 02:11 PM
XM 1's Avatar
Default How to clay bar
are there any special techniques to use for clay bar the car??
like only clay in one direction or something like that.
thx
Old Sep 14, 2006 | 02:20 PM
superchargedg's Avatar
superchargedg
Damn Noobs
thx
make sure you go back and forth in the same direction and also use plenty of qd spray as lubricant.(qd means quick detail spray in case you didnt know).also dont apply to much pressure,also use a very light pass.
Old Sep 14, 2006 | 02:27 PM
plumpzz's Avatar
plumpzz
Do it in small sections and when the car is cold. ALso use a lot of lube and clean it off after you do that section, otherwise it sticks and its pretty hard to take it off w/ soap. Do the areas behind teh wheels and on the front grill and front bumper for the biggest difference. You'll take off whole chunks of dirt you never saw.
Old Sep 14, 2006 | 02:31 PM
mikeg8r's Avatar
mikeg8r
thx
The clay should not be introducing scratches to your finish so the direction really shouldn't matter. Use a lot of spray lubricant on the clay and on the surface and let the clay do the work. If your fingers are going thru the clay then you are pressing too hard Don't forget to refold the clay periodically to get a fresh side facing the paint.
Old Sep 14, 2006 | 02:44 PM
JDMFairlady21's Avatar
JDMFairlady21
good info here... you can also look it up on autopia.org
Old Sep 14, 2006 | 05:21 PM
rockinbboy's Avatar
rockinbboy
Is the Quick Detail spray the recommended lubricant? I thought clay bar has its own lubricant? Can a clay bar be purchased at an auto store like Pep Boys?
Old Sep 14, 2006 | 05:40 PM
Ky Z's Avatar
Ky Z
You can use a mix of soap and water too.
Old Sep 14, 2006 | 11:20 PM
XM 1's Avatar
wow awesome, helped me alot
will do clay bar tomorrow if weather is fine
ordered the meguiar´s clay bar "kit", it comes with a lubrication
Old Sep 17, 2006 | 05:31 PM
scottycameron's Avatar
scottycameron
I got the Mothers kit at Autozone, came with the bar, detailer and a small bottle of carnuba wax. $16 I think.
Old Sep 18, 2006 | 11:24 AM
VO...'s Avatar
VO...
Administrator
good info guys.. I've planning on claying my car soon..
Old Sep 18, 2006 | 12:21 PM
jtabraham's Avatar
jtabraham
it definately makes a world of difference. You can actually hear the bar removing the contaminants from your paint surface. If you drop the bar, it's as good as gone...toss it and drop some more cash on a new one
Old Sep 19, 2006 | 07:40 PM
JhayRCruz's Avatar
JhayRCruz
Claybar does wonders!! I jus bought the Mothers Claybar wit detail spray. Do small sections and spray often wit the detailer while using the claybar. Use up or down or side to side pass.
Old Sep 19, 2006 | 10:47 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
I organised a Meguiars night for one of car clubs I'm in NZ for the second time this year & yes they recommend using the Quik Detailer in conjunction with the Clay Bar. I don't know about in the USA, but in NZ you generally buy a pack that consists of Clay Bar and Quik Detailer. Hope that helps.
Old Sep 20, 2006 | 02:20 AM
BRONZEE's Avatar
BRONZEE
Club Moderator
This may or maynot help, but an interesting video none the less. Watch an expert groom a car. Paul Dalton commands in the order of 5 thousand pounds (yes, English pounds or sometimes more) to groom a car.
Anyway check this out.
http://youtube.com/watch?v=xAPvDIpI6HQ
Old Sep 20, 2006 | 02:36 PM
zdotcom's Avatar
zdotcom
Really like how he puts on the wax with his hands.
Old Sep 21, 2006 | 12:42 AM
BRONZEE's Avatar
BRONZEE
Club Moderator
Haha, but that only works with pure Carnuba wax, not with synthetic polymer wax.
But yeah, it's pretty cool!!
Old Sep 21, 2006 | 05:53 AM
zdotcom's Avatar
zdotcom
Wax on...Wax off! Good Daniel-san!
Old Oct 9, 2006 | 03:41 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
I just claybarred my car for the first time using the Zaino claybar, water, and quick detailer...all I can say is zaino=sex
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
