CA Blade caused major Clear Bra damage!
Old May 1, 2003 | 06:34 PM
afr0puff's Avatar
afr0puff
Default CA Blade caused major Clear Bra damage!
I need help!!! I put a little too much pressure using the blade on my car. It folded in on itself and the rubber stem area streaked against my clear bra. It left a nasty streak. Very Very very noticeable! I tried rubbing it, but no luck. Any ideas?
Old May 1, 2003 | 07:03 PM
ruacop2's Avatar
ruacop2
Depending on how bad the scratch there might not be anything you can do about it. You can try polishes by hand or a buffer at low rpm. Also you can try Plexus or Meguiars number 9.
It is hard to say without seeing a pic
Old May 1, 2003 | 09:47 PM
rodH's Avatar
rodH
Default Re: CA Blade caused major Clear Bra damage!
are you talking about the hard plastic handle that did it??
Old May 2, 2003 | 06:23 AM
afr0puff's Avatar
afr0puff
Default Re: Re: CA Blade caused major Clear Bra damage!
No, it was the rubber. See the fold point here? It folded in completely and that portion streaked against my clear bra.
Old May 2, 2003 | 08:06 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
guess it's not meant to be used on plastic type of material..
Old May 19, 2003 | 05:18 PM
afr0puff's Avatar
afr0puff
Well... it took a professional detailer about 20 passes with an orbital buffer using 3 different types of polishes. It's next to gone. You can barely see it, only if you know where to look and at the right angle.
Old May 19, 2003 | 07:25 PM
ruacop2's Avatar
ruacop2
Glad to hear you got it taken care of.
wanderingstuden
Jan 28, 2016 07:03 PM
Cashwin
Oct 1, 2015 06:36 AM
