damn uhaul stained my 07 ppw
i recently moved to texas from north dakota and either the uhaul or the uhaul trailer peppered my 07 ppw with some kind of fluid that is like a yellowish tint... i washed it and it never came off i used bug and tar remover and then i washed it again and it STILL hasnt come off.........
is there anyone that would know what it is? anyone know what i can use to get that **** off? HELP
Well I wouldn't have used bug and tar remover. Like idwin said, Dawn dishwap soap will strip it down pretty good...then claybar it and polish it. If polishing doesn't fix it, then it's *&%(#D. Hopefully it will and then you can slap some wax on it.
Worse comes to worse...sue em! This is America afterall, right?
what is claybar? where can i pick it up? dawn and then claybar to it wont mess up my clear coat will it? (oh and i cant get any good pics but you can deffinately tell if you just look at it i will try to get a good camera and good lighting and try and post up some pics, after i try dawn and claybar first)
If it won't wash out and it appears to truly be a stain, then you're going to need some kind of polish or polish/cleaner. Unlike a wax, a polish/cleaner will remove a small amount of the clearcoat leaving you with a clear surface again.
You can buy it in a kit...Mothers or Meguiars...Autozone, Advance Autoparts, Pep Boys, etc.. I'm sure they all carry it. If you feel like waiting, you can go for higher end stuff from Autogeek or Autopia...but they really all do the same thing.
Originally Posted by davidv
If you are uncertain about grades of polishing compounds, and how to use them properly, then take the car to a pro. No point in making the problem worse.
im not sure if it was the truck or the trailer... either way it still got stuff on there......... anyways, i tried using the claybar.... didnt work what should i do now? should i call uhaul and have their *** pay for the next step or what is the next step i could do without sanding or paying big bucks?
Originally Posted by Ztalker
Woooow. Washing a car gets tedious after a while, but using that top-of-the-line stuff and being able to be in presence of such nice cars would make it worth it. Also the fact of making 5000 pounds per car...
