bird doo doo
Old Sep 18, 2007 | 11:37 AM
stylett9's Avatar
stylett9
Default bird doo doo
So i saw some orange/brown bird doo doo. I washed it off right away because i heard if you leave it, it can ruin the paint. So i got all the surfance doo doo off but i can still see fades of orange on the paint.. I try rubbing and it feels like its in the clear cloat(because its smooth)
any suggestions on how to fix this?
thanks
Old Sep 18, 2007 | 11:51 AM
05Z33's Avatar
05Z33
try buffing it out with some wax, if that dosen't work try a clay bar. Good luck. At least you had your windows up, I had mine down and a bird crapped on my interior on the door panel and that was hard to get off.
Old Sep 18, 2007 | 12:01 PM
VO...'s Avatar
VO...
Administrator
The title made me LOL!!!
Old Sep 18, 2007 | 12:29 PM
gismo's Avatar
gismo
i have that exact same problem. i'll try waxing and buffing it out and if that doesn't work then i'll try that clay. damn bird dropping
Old Sep 18, 2007 | 12:41 PM
JasonZ-YA's Avatar
JasonZ-YA
Ha...ha... same here! i knew exactly what was coming....
Old Sep 18, 2007 | 02:11 PM
engiNERD350Z's Avatar
engiNERD350Z
Use 3M rubbing compound. Then follow up with Meguiars scratch X. Trust me, it will work. You need to use both though. Finish with wax.
You can find this stuff at pep boys,etc. Be careful not to rub too much away clear coat with rubbing compound. Just enough to smooth it out. Do a search, others have done it this way.
Old Sep 18, 2007 | 02:13 PM
dieselmcore's Avatar
dieselmcore
I'd Say use some steam, like from a steam Clothes Iron or something... I guess that should do it....
Old Sep 18, 2007 | 10:13 PM
joe645733's Avatar
joe645733
lol possibly bubble the paint. no biggie.
and no, claybar wont work. need to buff. and ur not supposed to buff with wax, u dont want to shine it. use the right supplies if ur going to buff your car. if u BUFF wax over it, it can posssibly stay forever. ull work it into the paint so fast from heat.
Old Sep 20, 2007 | 09:08 AM
KManZ's Avatar
KManZ
Scratch X has worked for me in the past. You gotta work it a bit though, 2 or 3 rubbing sessions. Then you wax over it. I never tried the 3M rubbing compound, I might have to check it out.
Old Sep 20, 2007 | 09:25 AM
z350boy's Avatar
z350boy
FYI: Baking soda mixed with water @ 50/50 mixture should be applied as soon as you find the offending product on your car. The baking soda neutrealizes the acid in the bird dung. I usually apply enough to soak the area, let it sit fior a few moments, then use a hose to wash it off ( or cloth soaked with water if it is a small spot). Then proceed to wash your car.
Old Oct 18, 2007 | 03:53 PM
JonsilvZ's Avatar
JonsilvZ
I never let doo doo sit on my car for long. I always have detailer spray and towels in my car.
Old Oct 20, 2007 | 08:21 PM
Yokohamaz's Avatar
Yokohamaz
http://www.properautocare.com has bird crap remover. Works well. It is a marine item they ported over to the auto side.
HoneyBadgerRy
Sep 21, 2015 03:25 PM
Red350Z
Cleaning & Detailing
Apr 16, 2003 09:53 PM
DIGItonium
Oct 5, 2002 03:05 PM
