How to clean water spot on windows & paint?
Old Oct 16, 2007 | 02:51 PM
hidehide's Avatar
hidehide
Default How to clean water spot on windows & paint?
I have parked my car on street every night. And the watering in the street makes the right side of my car has tons of waterspot..
Today I went to car wash, the water spot cant get out..
Do you guys know what do I need to use to get those water spot out??
Thanks in advance..
Old Oct 16, 2007 | 03:02 PM
SuperBlack350z's Avatar
SuperBlack350z
try a light abrasive polish and if that doesn't work, user a heavier polish. If you have no money at the moment, lightly wipe vinegar on it to see it they come out and not etched in the clear.
Old Oct 16, 2007 | 03:06 PM
DavesZ#3's Avatar
DavesZ#3
^^ Yup, try a 50/50 mixture of vinegar and water. That will dissolve most mild water spots.
Old Oct 16, 2007 | 05:14 PM
hidehide's Avatar
hidehide
Will that harm the paint too? it heard ppl say mix venegar with water for cleaning windows with water spot..
and wt vinegar?? those that we bought in supermarket??
Old Oct 16, 2007 | 06:46 PM
SolarOrangeZ's Avatar
SolarOrangeZ
Will it mess with my zaino layers?
Old Oct 16, 2007 | 06:59 PM
DavesZ#3's Avatar
DavesZ#3
No, the only things that can remove Zaino are alcohol or an abrasive polish.
Old Oct 16, 2007 | 07:25 PM
SolarOrangeZ
Hell yea, do you think I can mix vinegar with some soap and water and put it in my foam gun, you think that'll help with waterspots?
Old Oct 16, 2007 | 07:26 PM
SuperBlack350z
what kind of foam gun? Those cheaper ones from lowes or walmart? Or the gilbert ones?
Old Oct 17, 2007 | 08:39 AM
Spec_Tacular's Avatar
Spec_Tacular
I have heavey water spots on the glass of my car. It was like it when I bought it and I have tried an Acid we have at the dealership with very fine steel wool, I have tried glass cleaner with a razor blade and I can't get it off at all.
Does anyone have any idea how to get 3 yr old water spots off?
Old Oct 20, 2007 | 08:22 PM
Yokohamaz's Avatar
Yokohamaz
Glass scrub from http://www.properautocare.com will remove them. (on glass of course.) They have other tutorials to remove water spots on paint.
Old Oct 20, 2007 | 11:39 PM
hidehide's Avatar
hidehide
I tried the vinegar route, but I still cant get the water spot away!!
Should I try clay bar??
Old Oct 21, 2007 | 08:57 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
Clay bar will remove very light etchings on the painted and glass surfaces. Unless they are very light you will probably need to polish them. Initially we recommend using a medium cutting polish followed by a light finishing polish. The first polish is a medium cutting polish (Menzerna Intensive Polish) that will buff an ultra fine layer of clear coat where the watermarks have etched themselves into. This will also help remove imperfections such as oxidation, fine swirls and light scratches. A medium cutting polish can leave a slight haze behind so we always recommend using a lighter cutting polish after, also known as a finishing polish (Menzerna Final Polish II). These polishes use extremely fine abrasives that will eliminate any haze and make sure the surface is optically clear and glossy. This two-step process will allow more light to pass through the clear coat so you get a deep reflection from your paint. These steps may sound a little intimidating but it’s really very easy to do and yields some pretty amazing results. These results are usually better with a buffer like the Porter Cable 7424.
For the glass I would use the Glass Science Glass Scrub. This solution easily removes the etchings and leaves the glass clean and clear.
Let me know if you have any questions about these products or any part of the process.
Greg @ Detailed Image
Old Oct 21, 2007 | 10:03 PM
aleicgrant's Avatar
aleicgrant
I just discovered a whole bunch of water spots on my 07 Pike Peak White 350. They are only in the hood and unless you look at the right angle not easy to see. But once you catch them its a water spot farm. What light do you guys use to photograph these so I can determine if using the polish routine you mention. I am a little apprehensive about attacking such new paint as the car is an 07 with 1200 miles on it. At first I honestly thought it was a paint defect !!!!
Old Oct 21, 2007 | 10:10 PM
SuperBlack350z
yeah, most hard on water spots will be on the hood. Your hood gets hot so water bakes into it. Just polish them out.
Old Oct 21, 2007 | 10:33 PM
aznriceball2's Avatar
aznriceball2
the plastic on my headlights are foggy, wondering if its water spots and how to get rid of em?
Old Oct 21, 2007 | 10:35 PM
SuperBlack350z
wetsand them and buff them out. I think you are referring to hazing.
Old Oct 21, 2007 | 10:47 PM
bboypuertoroc's Avatar
bboypuertoroc
That's not water spots. Trust me, you'll know a water spot if you see it. It looks like, well, a spot. For example, if it rains and the water starts to dry, it looks like a bunch of tiny rings all over the car... those are water spots.
Old Oct 22, 2007 | 08:57 AM
Detailed Image
Detailed Image
I can understand that with such a new vehicle you probably didn't want to polish so soon. I always recommend you find the least aggressive solution to any situation. WIthout seeing or expirementing on your paint its hard to know what combination of polishes is needed to remove the watermarks. I'd recommend you start off with a finishing polish and use more aggressive polishes as needed. In my experiences most watermarks need at least a medium cutting polish and sometimes a heavy compounding polish. You can start with just the finishing polish but you may also want to at least pick up a medium cutting polish as well. I'd suggest the Menzerna Intensive Polish (medium) and Final Polish II (finishing) to start with. If you think the marks are deeper or if you can't polish them out I'd suggest the Menzerna Power Gloss (heavy). Even if you use all three of these polishes with an orbital buffer you'll remove a negligible amount of clear coat.
Let me know if you have any questions about this process or the products/tools involved.
