303 is causing spotting
Old Jan 15, 2008 | 01:15 AM
orbitalpunk's Avatar
orbitalpunk
Default 303 is causing spotting
what would cause spotting on the vinyl. i tested it on the inside of the door. did i not use enough 303? did i not dry it enough? its been like that for 2 months now.
thanks
Old Jan 15, 2008 | 01:21 AM
ZSpectrum's Avatar
ZSpectrum
thanks
did you apply it directly to the panel or to a towel first. z door panels are notorious for spotting. Apply it only to the towel and then wipe it on thouroughly.
Old Jan 15, 2008 | 06:37 AM
Detailed Image's Avatar
Detailed Image
Detailed Image
I typically apply 1 - 2 sprays to a microfiber towel and work the product in to the vinyl. You should try not to saturate the surface with product. If the surface feels very dry or rough you can apply the Leatherique Rejuvenator Oil. This helps soften the vinyl a little bit and look better.
Greg @ Detailed Image
Old Jan 15, 2008 | 11:03 PM
orbitalpunk
I didnt spray directly on the panel. i did it on a cotton towel. not alot. like 3,4 sprays. i thought my i didnt use enough that iti didnt cover the entire surface. is there a way to remove the spotting? is it permanent?
thanks again
Old Jan 16, 2008 | 02:20 AM
ZSpectrum's Avatar
ZSpectrum
thanks again
soap and water, Im dead serious. Or just apply more to it, and rub in real fing well.
Old Jan 16, 2008 | 09:35 AM
Detailed Image
Detailed Image
thanks again
The 303 products and detailing products in general are often optimized when you use just enough. Excess generally provides no benefit and can often be to the detriment of quality detailing. It's hard to say if the spotting is permanent. I think your best bet is to condition the vinyl with a product like the Leatherique Rejuvenator Oil I mentioned above. This is one of the few products I'll apply a little more generously or multiple coats of. I would wipe it on with a clean applicator pad and let it soak in. If it soaks in really quick I would apply more as needed. When you're done take a damp clean cloth or microfiber towel and wipe the excess product away. Let me know if you have any questions about this process or the recommended products.
loudtoyz
Apr 6, 2023 04:52 AM
ablaine
Nov 29, 2016 10:13 AM
wanderingstuden
Jan 28, 2016 07:03 PM
_bit
Oct 2, 2015 07:49 AM
