advantage using porter cable?
Old Jul 1, 2003 | 03:53 PM
s9am_me's Avatar
s9am_me
Default advantage using porter cable?
i'm thinking about buying one... anyone have one or recommend a good/inexpensive one?? getting tired hand waxing my cars. is it fast enough to etch off a little bit of the clear coat?
Old Jul 2, 2003 | 08:12 AM
zwindsor's Avatar
zwindsor
Twisty addict
I've only use a buffer to remove wax not apply it. It's recommended that you apply waxes in a linear motion (at least Zaino) but most everyone still uses a circular pattern.
Griot's has a complete package for the Porter-Cable system. I believe it is variable speed so you can keep it on a low setting. A little pricey. I looked into this once and was able to find the same unit at a tool site for about $150.
http://www.griotsgarage.com/catalog....2060&SKU=10625
I have a Waxmaster (Kragens $50) that I only use on my Toyota (older paint). The Z gets everything done by hand. Zaino is easy to work with.
Old Jul 2, 2003 | 01:08 PM
ares's Avatar
ares
Veteran
theres no damage done by them I dont think. but if you get a high speed dont use swirl remover or anything or it could go through, but as long as there is no polishing compound in it, no problem.
it will waste alot of was if you use it to apply it. and if you use an expensive wax, that would be bad.
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
hulkout
Tuning
Sep 18, 2015 05:42 AM
